mounting potentiometer on pneumatic cylinders
Discussion in 'SimTools compatible interfaces' started by ch@rles, Jul 27, 2010.
  1. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Hello
    i search information (pictures) on the mounting potentiometer (faders) on pneumatic cylinders?
    Sincerely yours, Charles :cheers:
    sorry: for my bad english :tape:
  2. yobuddy
    51,194Coins
    You could make homemade string pots with the springs from cheep tape measures.
    Once you find the right size tubing for the sting to wrap around, they are pretty easy to make.
    You can connect then to the cylinder with pipe straps.
    anyway, just one idea.
  3. riton
    riton Active Member
    1,006Coins
  4. ch@rles
    ch@rles New Member
    Bever (Belgium)
    353Coins
    Thank you for the pictures it gives me an idea how to achieve
    Merci pour les photos ça me donne une idée comment les réaliser
    Thanks Charles :hi: :thbup:
  5. douwe
    douwe New Member
    Heemstede (NL)
    731Coins
  6. Frakk
    Frakk Active Member
    328Coins
    Thanks for all these great ideas everyone!
    The string could introduce some error in the position, but great results could be achieved if done properly especially with multi turn pots.
