Question Problem with uncontrolled motor rotation in the opposite direction at random times
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Miszor, Nov 16, 2024.
  1. Miszor
    Miszor New Member
    114Coins
    Hello, today I will probably break the record for questions on the forum, but I would like to ask one more thing that is important to me. I managed to successfully configure SMC3 Utils and SimTools, but I have a problem with uncontrolled rotation of one of the motors in the opposite direction. By default, the range of motion should be a few degrees from the "0" position, but in my case it rarely happens that the one motor starts turning in the opposite direction by 360 degrees. I don't know whether it will make one turn or several in the opposite direction, because the arm has an aluminum profile in its path that stops the motor. After switching on the power (Arduino and motors) again, the Hall sensor reads the positions correctly and the motor is ready to work again. Today it happened to me 3 times during the day. I use 250W 75 rpm motors, Hall sensors and IBT2.
    152,189Coins
    +11,064 / 56 / -2
    Can you please post pictures of the SMC3 settings for the problem motor running the Sine test.
  3. Miszor
    Miszor New Member
    114Coins
    Here is a screenshot, the settings are the same in the second motor, but such things do not occur there
    152,189Coins
    +11,064 / 56 / -2
  5. Miszor
    Miszor New Member
    114Coins
    Thanks for the reply, actually when I went to SimTools I forgot there was anything else in the manual. Tomorrow I will set these parameters and test further. I hope this helps
  6. Miszor
    Miszor New Member
    114Coins
    I analyzed these parameters. The Clip Input and Max Limits values match the design limits of my platform. I would even say that the value of 255 is not enough. I need something to slow down the movement when the values are approaching the max. Is this what the PWMrev parameter is for? Maybe I could use it to ensure that it does not exceed the limit values
    152,189Coins
    +11,064 / 56 / -2
    Yes, PWMrev is used to drive the motors in reverse (hard brake) if they enter the limit zone.
  8. Miszor
    Miszor New Member
    114Coins
    This parameter doesn't seem to work for me... After setting it according to the recommendations (the same value as PWMmax), after exceeding the Max Limit value, the engines turn off and I have to manually move them again to be able to turn them on again.
  9. Miszor
    Miszor New Member
    114Coins
    Maybe I'll explain the problem in more detail, because it happened again. I tested motor 1 (I have problems with it) in MOTION mode, then I selected the manual option to reset its position and move on to testing motor 2. Motor 1 reset its position so I selected the Motor 2 option and then Motor 1 made an uncontrolled rotation in the opposite direction by approximately 270 degrees. Now, after running SMC3 Utils, I see that the zero position of the Hall sensor in Motor 1 has been lost and is in a different place than it was set. The behavior of motor 1 with this rotation resembled something like free movement, as if it received a momentary current surge that allowed it to rotate. Could it be the fault of the Hall sensor, which loses its position, which causes the motor to suddenly rotate to obtain a new "0"? The belt is tight, it is unlikely that it will jump
    152,189Coins
    +11,064 / 56 / -2
    Turning off after exceeding parameter is a safety feature.
    152,189Coins
    +11,064 / 56 / -2
    Are the Has sensors properly centered, they are not like a pot so can be rotated past their functional range.
  12. Miszor
    Miszor New Member
    114Coins
    What do you mean by the ability to rotate them outside the functional range? If the Green line in SMC3 Utils goes up or down from center (caused by rotation) a break occurs and the chart reappears from the opposite side and re-centering is possible. At least that's how I understand it, maybe I'm making a mistake somewhere in the physical setting of the sensor.
  13. noorbeast
    152,189Coins
    +11,064 / 56 / -2
    A Hall sensor does not have a physical stop, and works with a magnet, so say it is a 180 degree type it can be rotated way pass that and the magnet field can still be in play.
    Power off the motor and disconnect the Hall sensor from it, turn it by hand through its full range while watching SNC3 and make sure it is correctly centered.
  14. Miszor
    Miszor New Member
    114Coins
    I'm using the P3022-V1-CW360 model, so it's probably the 360-degree version. I don't know if it is possible to set the "0" position incorrectly. But I'll try to manually find it again tomorrow.
  15. Miszor
    Miszor New Member
    114Coins
    Ok, I'm done with the next tests. I will describe the situation:
    1. I disconnected the motor from the sensor, set its zero position again, then connected it to the motor again
    2. All tests worked, motion, sine, etc. Switching between motors also caused no problems.
    3. I moved on to testing in SimTools and LFS, there too without any problems, I drove about 10 laps.
    4. I turned off the platform, disconnected it from the power supply and USB. After some time, I came back to test again, also in LFS I did not encounter any problems. After completing the tests, I turned off SimTools and switched to SMC3 Utils (I did not turn off the motors' power or disconnect the USB cable). When I started SMC3 Utils, the problematic motor once again rotated in the opposite direction by about 300 degrees, establishing a new zero position of the sensor (Even though the "Monitor" option was set). I don't know if the belt jumped, it probably shouldn't because it is stretched just like in a motor that has no problems. Conclusions: I would love to know if all my steps are correct. Maybe I shouldn't run SMC3 Utils after SimTools was running, or the motors shouldn't be powered on when SMC3 starts. Only from what I remember, uncontrolled rotation also happened to me yesterday in LFS, so I don't know if it's specifically SMC3 Utils' fault. I would assume that either IBT2 or the hall sensor is damaged.
    I would also like to add that at the very beginning, when starting the motors in SMC3 Utils for the first time, I made a mistake, as a result of which the motor with which I now have a problem rotated uncontrollably. This was because I accidentally connected + and - from the power supply to the M+ and M- inputs, and the motor to B+ and B-. After swapping the connections, everything started working, but now I have problems with this motors. I wonder if an incorrect connection could have damaged something, causing such strange things to happen now.
  16. noorbeast
    152,189Coins
    +11,064 / 56 / -2
    Yes damage is a possibility from incorrect wiring.
    You can't run SMC3 Utility and SimTools at the same time, as that will cause a port conflict, but each should work if independently run.
  17. Miszor
    Miszor New Member
    114Coins
    So, would you suggest replacing IBT2? It's a bit strange because I don't know if it has anything to do with the position. But I've already ordered spare pieces, they're not expensive.
    As for running at the same time, yes, I know that they cannot work together. When I turn one on, I turn the other off.
  18. noorbeast
    152,189Coins
    +11,064 / 56 / -2
    First try swapping it to the other motor and see if the problem follows or not, that should help determine if it is damaged or not.
