Showroom 6DOF Project - Design - Build - Race
Discussion in 'DIY Motion Simulator Projects' started by azm, Nov 18, 2024.
  1. azm
    azm New Member
    65Coins
    Hello everyone!
    My brother and I, we join the xsimulator community ... Our plan --> build 6DOF platform. Fingers crossed :)
    In short, this is the master list...
    Platform:
    • Rotary Stewart Motion 6 DOF with servo actuators through planetary gearbox - DIY
    • Steel Main Frame - DIY
    • Aluminium Top Frame - DIY
    • 3x Displays - BUY
    Peripherals:
    • Steering wheel - servo motor with 11.5Nm and FOC motor controller flashed with custom firmware - DIY
    • Handbrake - 1x Load Cell with 2x buttons, aluminium frame with adjustable tension and damping - DIY
    • Pedals - 1x Load Cell (Brake) and 2x Hall-based pots (Accelerator and Clutch), aluminium frame with adjustable tension and damping - DIY
    • Shifter H - for 6 hears + R, aluminium frame with real-life feeling - DIY
    • Shifter Seq - up and down detection, aluminium detection with pre-tension - DIY
    Controllers:
    • 6DOF Thanos as controller - BUY
    • USB BoB - Peripheral connections (brain and electronics for Pedals, Handbrake, Control Box, Shifter, etc.. ) - DIY DIY
    PC (unclear, but deff not DIY)
    Power Supplies (unclear, but deff not DIY)
    And master timeplan!
    Timeline plan:
    1. Handbrake (done, tested along with G27, works well with genuine feeling)
    2. Pedals (ongoing)
    3. USB BoB (ongoing - concept electronics done, alpha tests ok, new batch coming)
    4. Seq Shifter
    5. FFB Wheel (ongoing)
    6. Main Platform
    7. Bot Platform
    8. H Shifter
    We have access to laser cutting, laser etching with next to no costs. So that will be of huge help!
    About us
    Short about us, we are (in average) in mid twenties, working full-time job as automotive electronics engineer and automotive maintenance / machining technician. We have already finished 2 CNC machines, few RC airplanes, restored 2 VW Golfs (mk1 and mk2) and so on and so on. Needlessly to say, we are pumped ;)
    Looking forward to join you!
    hug:
    • Like Like x 5
    153,914Coins
    +11,156 / 57 / -2
    I am looking forward to following your project and progress!
    Any 6DOF is an ambitious project. So detail as much as you can before ordering and building, as members may have suggestions that may well save some time, frustration and money.
  3. azm
    azm New Member
    65Coins
    Thanks for the kind words! :thumbs
    Yes we are really documenting, drawing, modelling and reviewing everything before really ordering.
    Also did some quick and clean concepts, tested it to see if we are moving in right direction.
    Just as you said, to avoid any unwelcome surprises :)
  4. azm
    azm New Member
    65Coins
    Update #1 - Custom USB BoB
    As mentioned, we decided to make custom USB BoB. And whenever you make something, first you need to define what you want to achieve - specifications. And the picture shows more than thousand words :)
    Idea was to make ultimate expansion board, easy to use, robust and with more than just basic functionalities. Versatile. Board shall contain:
    - pedals (1x load cell for brakes and 2x potentiometer for accelerator and clutch pedal)
    - shifter (8x analog inputs with software defined thresholds)
    - handbrake (1x load cell, 2x buttons)
    - CAN (unlimited expansion possibilities))
    - USB connection to PC
    - ESP for WIFI and Calibrate-by-app
    - Controls (at least few Encoders,/Potentiometer and some Buttons)
    - I2C expansion (e.g. for OLED display)
    - Power Supply
    - Indicator LEDs
    So we have done some concepts in the past few weeks, ordered PCBs from JLCPCB and did some software for verification of the design. So far, so good! Hooray.
    So last weekend (incl today) I spent designing the target PCB with all connectors... and so Jeronimo was born ;)
    The front is plain 2-4mm (adjustable) single plate. It can be either aluminium or acrylic or even wood. Its meant to be removable so we can drill holes and make slots for possible buttons, potentiometers and encoders (these are not visible on the model, as that is planed for later)
    Ooopsie, that's just the aluminium case...
    The back side of the case contains the PCB. It is multi-layer and satisfies generic electrostatic and impedance standards. It has several connectors and expansions possibilities.
    - 1x DB9 connector for pedals (3x load cell / potentiometer)
    - 1x DB9 connector for shifter (8x analog inputs with software defined thresholds)
    - 1x DB9 connector for handbrake (1x load cell / potentiometer, 2x buttons)
    - 1x RJ45 (ethernet) connector for CAN (unlimited expansion, 2 amp max)
    - 1x USB Micro B connection to PC
    - 1x ESP01 connector for WIFI and Calibrate-by-app
    - 1x Control Board Expansion (2x Encoder, 2x Potentiometer, 6x Buttons)
    - 1x I2C expansion (e.g. for OLED display)
    - 1x Power Supply Jack (5-12V)
    Or better yet... in picture!
    So design is frozen, PCBs soon ordered and meanhile we will continue on Pedal and Handbrake assemblies!
    Stay cool! hug:
  5. azm
    azm New Member
    65Coins
    Hey yo! Hope you doing well during Christmas holidays! hug:
    We are currently working on wheel and electronics.
    Wheel - drilled the shaft, milled the rotor, mounted the encoder sensor through the shaft, mounted quick release coupling, wired all the electronics and did some initial tests. It seems all goes well, except that motor+brake resistors get hot too soon. So one of next steps for motor is cooling and aluminium sheet housing for better heat transfer. Then wheel is pretty much done
    As for handbrake, parts are ordered, still waiting for laser cuts.
    H-shifter has gone under 5 different concepts. The problem is "the real life feeling", because it needs to be robust machanically but stil smooth. Lets see. I think thats going to be the hardest part yet. Looking good tho ;)
    Biggest advance was on USB BoB - Jeronimo. Thats where we added Fan/Blower support and OLED display connector. We are thinking to add one interface for active shifting, buuuut, we need more thinking here. Additionally, we are migrating to 4layer PCB to be able to deliver high power seamlessly.
    And we will put it on the KICKSTARTER!! :rolleyes: Because honestly, there are next to no such versatile boards :)
  6. Wiley
    Wiley New Member
    22Coins
    Motion platform, 6DOF
    Looks like a great start. I dove off the deep end with my simulator by ordering the Thanos controller, 80ST motors and 50:1 gear boexes etc. while still finalizing my design and support cage. I too have a rotary Stewart rig in mind. Have you finalized a seat, pedals and shifter support design?
    I’m thinking about either tubular bending (steel or aluminum) a frame or bonding carbon fiber tubes with webbed joints.
    I look forward to the progression of your build
    Cheers
