Question Noise when testing output from Simtool
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Vigis1982, Nov 16, 2024.
  1. Vigis1982
    Vigis1982 New Member
    - 71Coins
    I am building a 2DOF simulator using arduino and IBT-2 motor driver. When I test the motors with SMC3-Util, I get perfect output. But at the moment when I test the output in the sim tool, the output data at certain moments are noisy as you can see in the picture.
    I tested it without SMC3-Util using Serial interface and the result is the same.
    Has anyone encountered this, can you advise how to solve it.
    Thank you.
  2. Radioproffi
    Lviv
    1,677Coins
    looks like windows regional settings problem, try to set - US standard in windows settings
  3. Vigis1982
    - 71Coins
    Hi, I didn't believe it but it really helped! Thanks for your help.
  4. Radioproffi
    Lviv
    1,677Coins
    thanks for your feedback
