MSFS 2024 Plugin
Discussion in 'Flight Simulator 2020 - FS2020' started by Buj818, Nov 19, 2024.
  1. Buj818
    Buj818 Member
    282Coins
    Motion platform
    Has anyone heard any buzz on development of the MSFS 2024 plugin and it's possible approximate release date? I'm not aware how active developers here are writing plugins for new games, so I figured I'd just ask.
  2. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    827Coins
  3. pmvcda
    15,848Coins
    From what I know, Simconnect stays the same for motion... Maybe my ignorance, but waiting for the instal to conclude and will give some feedback.
  4. pmvcda
    15,848Coins
    Ok, simconnect works in FlyPTMover. Might need only a change in the exe name.
    Will add it to Mover, but only for helping in the startup from Mover, because it already works with the MSFS 2020.
    Did not test directions...
    So for Simtools it should also work.
  5. George Dobransky
    Hungary
    - 37Coins
    Hi there,
    I have tried, but simtools game manager cannot recognize the new fs2024's exe to start running.
    maybe we need a new plugin with updated parameters.
    George
  6. Pastrana
    Pastrana Member
    Argentina
    165Coins
    I'm interested in the plugin, hopefully I can add it soon.
  7. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Motion platform, 6DOF
    Myself as well my motion pc is win 7. version 3 wont in stall so i am screwed
  8. Hubert Czajczynski
    Hubert Czajczynski New Member
    34Coins
    Does anyone has it working ? Plugin launches with sim but no values in min/max. Other sims works ok.
    154,580Coins
    +11,190 / 57 / -2
  10. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    Hello did you you ever get MSFS2024 motion plugin for V2.6
    154,580Coins
    +11,190 / 57 / -2
    There is no MSFS2024 motion plugin for V2.6, and given V3 is nearing the end of Beta and already does have a MSFS2024 motion plugin, it is hard to imagine a dev putting time into a V2 plugin that would soon be depreciated, but perhaps someone is willing to give it a go: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
  12. iamcanadian2
    iamcanadian2 Member
    floating docks
    surrey bc canada
    90Coins
    So i bit the bullet and installed V3 on the flight PC and little difficult in getting telemetery out of 2024 but when I rebooted the pc it worked? Weird. Now i put Msfs 2020 and no limits on V3 , Good motion cues The only thing with 2024 i get like a KICK or a bump once and a while only on 2024... other than that feels good.
    Thanks for the work!
  13. Mauricio
    Mauricio Member Gold Contributor
    75Coins
    Hello friends!
    I have a 6dof platform and using SimTools on FS2024. Everything is working reasonably well, but I'm not able to make it 100% smooth. There are always some hiccups, like moderate turbulence. I've tried setting everything to 100% soft, lowering the intensity, etc. Any suggestions? Sounds like "noise"
    154,580Coins
    +11,190 / 57 / -2
    Hard to say without seeing your settings and a video of the issue, it could be electrical interference.
  15. Mauricio
    75Coins
    Thanks for the answer. Apparently I have no electrical interference. When I turn on simtools, even before I have entered the flight itself, the platform starts to make small random movements. Does this happen to you too? It's like there, you were already receiving data, and in my opinion this should only happen, at the entrance of the flight itself.
  16. noorbeast
    154,580Coins
    +11,190 / 57 / -2
  17. Mauricio
    75Coins
    Follow....
  18. noorbeast
    154,580Coins
    +11,190 / 57 / -2
  19. Mauricio
    75Coins
    Thanks for the help!
    At first I didn't see anything wrong. Why do you think it's the configuration? And a doubt. In your case, the platform moves, small jerks, as soon as the simtools or flypt move are connected? To me this doesn't make sense, as it shows that data is going well, even though the flight hasn't started yet.
  20. Joe Cortexian
    1,616Coins
    I see exactly the same behavior on mine. In some cases it just makes no sense. I don’t think it’s the plugin that’s just passing the information along that you hit a giant rock at 2000 feet altitude. MSFS 2020 was not much better.
    Is there a way in SimTools to log the data coming in ? That’s the only thing that might convince Microsoft to look at the problems. I don’t think they are interested unless it’s an XBOX issue.
    EDIT: I had a bad sensor. Also, heave was interfering with smooth flight.
