FlyPT Mover 3.7.0.15
  1. pmvcda
    15,497Coins
    Download here:
    LINK REMOVED, DOWNLOAD IN THE FIRST POST
    I wanted to correct that bug before posting the link here. But only later in the day...
  2. pmvcda
    15,497Coins
    Mover 3.7.0.6 BETA
    Note: I shared an earlier 3.7.0.6, please update to this one to allow future updates through Mover
    Download links updated to GitHub to avoid password protection
    Release notes:
    Corrected bug in the UDP output
    Corrected bug in Update
    If you are in 3.7.0.5 or earlier 3.7.0.6, you need to download the file manually
    Files are now hosted in GitHub to avoid passwords
    Moved to .Net9.0
    Work in module transitions, still with bug at 0%
  3. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    220Coins
    Always not sawp for only 1 motor in 2 dof.... no test possible for me...:(
  4. pmvcda
    15,497Coins
    Sorry, it's on the next one.
  5. pmvcda
    15,497Coins
    Can you tell me wich arduino you are using?
    Here I can connect to everything I have.
    Maybe try to install the drivers again (https://support.arduino.cc/hc/en-us/articles/4411305694610-Install-or-update-FTDI-drivers).
    If you could try this it would be of great help. Thanks.
  6. smitty
    smitty Active Member
    933Coins
  7. danlo2721
    danlo2721 New Member
    22Coins
    I am successfully using v3.5.3 in DCS to control my transducers using the supplied “DCS to FlyPT Mover.lua” script in the DCS/..Hooks folder. Now trying to do the same in V3.7.0.6 but it does not receive game data at all. There is no DCS lua script in the download with the new version and the old script only works in 3.5.3. Am I missing something? Thanks in advance.
  8. pmvcda
    15,497Coins
    It's using a new LUA file.
    In the new Mover, patching is automated.
    Go here (small button with pen) and apply the patch for the version you are running:
    You can also lauch DCS from here (small button with joystick):
    If you have problems, I can post the LUA
    Also there's many changes. Just ask for help if needed. User manual is still missing.
  9. danlo2721
    22Coins
    Thanks!!
    Sorry, totally missed those two icons. Up and running now.
    Time to get re-acquainted with the filters and remap all my transducers.
    Looking forward to a manual and thanks again.
  10. ricseixas
    ricseixas New Member
    - 3Coins
    3DOF, Arduino
    Can anyone have a mover setup for DCS for a 3 DOF . I’m using lebois Racing SRT100
  11. Avee
    Avee Virtual Pilot
    1,167Coins
  12. pmvcda
    15,497Coins
    Ok, I will add as an option (default=enabled)
    Will be on the new release later in the day
  13. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi @pmvcda: Today I set in Mover 3.7.0.6 a default settings from my rig for startup (set as default for Mover at startup) but forgot that the com-ports have been wrong in this setting-file.
    Now when I start Mover it allways crashes to desktop (see video).
    The problem is, that I can not remove this default setting at startup - it seems to stick to the Mover no matter what I do.
    Any ideas?
    Thanks a lot!!!
  14. pmvcda
    15,497Coins
    Ok, i can add a command line to start with all outputs disconnected. Kind of safe mode.
    Give me some time, i will post the build in the next hours.
    Or if you want to, go to the registry, search for Mover and delete the default setup. You will loose the setup...
    You can store it by copying the text to notepad and save it
  15. pmvcda
    15,497Coins
    Thinking better, this should not happen....
    Disconnect the usb cables and start Mover. Is it crashing that way?
  16. S2.
    S2. New Member
    Finland
    86Coins
    Trcaction loss from wheels don't work with Assetto Corsa.
    Is it that Assetto don't send slip angle data?
  17. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Thanks for your fast Support!
    Mover crashes also with this procedure.
    But deleting the default setup file in the registry did work
  18. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    This was the solution! Thanks a lot for your great support!
  19. pmvcda
    15,497Coins
    Have to check. I think not, only acc.
    Those tires are huge.... Need to check that also
  20. dano@GI
    dano@GI New Member
    22Coins
    3DOF, DC motor, Motion platform
    Hi Pedro. Just getting started with 3.7.0.6. First, thanks a lot for the amazing piece of software. I've been successfully using 3.5.3 to drive my rig, but trying to do some new things with features you've implemented in the new version. Realize you are working through a lot of bugs and comments in this beta, but specifically I'm trying to use the "DIV" operation to divide two numbers and can't get it to work. I've tried various inputs including just using "number" for both numerator and denominator. Basically what I'm seeing is is result is "1" if numerator is anything other than "0" and "0" if "0". Denominator appears to have no effect. Appreciate it if you could let me know if this is a bug or if I'm misunderstanding this operator. Thanks again!
