Resolved 360° hall effect potentiometer and SMC3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by michel123, Nov 26, 2024.
  1. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    I searched everywhere in the forum, but I must not be smart, I can't find the answer to the following question:
    I have hall effect potentiometers at 360, but under SMC3 when my potentiometer reaches its highest level it switches to low (I understand that it is in fact a voltage tap +- 5 volt or 2 ,5...), I would like to make SMC3 understand that I have a 360° potentiometer and not 180!
    Is there a parameter in the arduino code (pot scaling????) that allows me to manage this problem.
    The chair itself works well, but when I stop the power my chair gets up and puts my potentiometers at the maximum height travel, I therefore exceed the limit value in SMC3, and if I restart the power, suddenly my motor goes in the opposite direction to what it should operate.
    I therefore always have to help my wheelchair when starting to lower it while it starts, and I would therefore like to avoid this by having potentiometers that operate at 360°...
  2. Aerosmith
    Aerosmith Active Member
    self employed
    2,887Coins
    3DOF, AC motor
    I think this is just an offset problem. The 360° sensor has no stop so it rolls over to 0° if it goes above 360°.
    Make sure the center position is correct. Move your arm to the neutral position (with the motor power off). Loosen the set screw of the coupling (or take the belt off) and turn the potentiometer until the output is 2.5V. Then tighten the set screw (or put the belt back on).
  3. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    I've already done that, and the chair normally works very well.
    The problem is that if I make my lever arm do a 360 degree, under SMC3, the rocker of the potentiometer line jumps, as soon as it reaches the top (roughly 90 degrees at the top), it jumps down to start again.
    Under SMC3 basically I have a coding which corresponds to a 180° not a 360, it is not sinusoidal when it reaches the stop at the top, it leaves from the bottom!?......
    If I stay in the range without going to the high or low end, my potentiometer works very well, and the signal is indeed sinusoidal.
    So I suspect a modification has been made to the SMC3 code, for example I have not validated the linear or non-linear pot option... but I tested and it seems to be the same....
  4. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    I think I understood why I can't have the entire range of my potentiometers under SMC3...
    My hal effect potentiometers are 360° with a range of 12 bits... SMC3 manages 10 bits.
    And secondly SMC3 was designed not to exceed a certain limit (therefore designed to only manage 180° max!).
    Apart from re-writing an SMC3, I would need to find another software that manages the 360 rotation of a motor and its control... if anyone knows of software that manages this?
    153,914Coins
    +11,156 / 57 / -2
    May I ask for a picture of the rig in which this is to be used.
    My reason is that you mention a lever being employed.
    While a Hall sensor may be 360 degrees, I can't think of a physical application with a lever that makes sense, in terms of actual effective torque utilisation, where that would seem useful to exceed around 80 degrees total of the lever motion. What I mean is τ = r F sin(θ): https://www.omnicalculator.com/physics/torque
    In other words, some clarity as to the actual use case would be helpful.
  6. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    <a href="https://zupimages.net/viewer.php?id=24/48/wnke.jpg"><img src="https://zupimages.net/up/24/48/wnke.jpg" alt="" /></a>
    When the chair is stationary (angle of more than 180°...)
    and when he works, normal angle...
    As soon as I start, as it can't find the right data from the potentiometers it tilts the arm to the left when it should go to the right... that's mainly my problem, I have to lower it with the arm on the right side before starting the arduino card........
    My original construction allows 360° rotation without breaking anything, I always think about the bug that could happen, hence the possibility for my chair to have motors that run in circles without problems (apart from the torque !!!)
    153,914Coins
    +11,156 / 57 / -2
    Can you please post a picture of your SMC3 settings.
    And when your motors are not powered can they be rotated?
  8. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    Below are pictures of a properly set motor arm, in addition, in your case you have more teeth in the pinion on the motor than on the potentiometer which has already been described on the forum that sometimes causes errors , you need to limit the swing of the motor arm max to +45 degrees / -45 degrees from the initial position ( motor arm horizontal to the base ). I printed myself the 86 tooth gears for the motor shaft and the hall sensor shaft so I have a ratio of 1:1. I can provide you with .stl files to print.
    Initial position
    Max UP
    Max DOWN
  9. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    Ok I just understood about the number of teeth!!
    I suspected something like that..... but I honestly thought that SMC could receive the 360° of the potentiometer....
    I'm interested in STL files and thank you for taking the time to show me and explain.
  10. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    Attila.pl as found the solution at my problem. And yes my motor can be rotated.
  11. Attyla.pl
    Polska
    1,336Coins
    The gears fit quite tightly, they may require some gentle filing to push them onto the axle properly
    153,914Coins
    +11,156 / 57 / -2
  13. Aerosmith
    self employed
    2,887Coins
    3DOF, AC motor
    I can't see all the pictures but from the one in post #5 my guess is that the gear ratio from the motor aoutput shaft to the hall sensor/potentiometer is more than 2:1. So when your actuator arm rotates 180° the sensor rotates >360° which causes the roll over in the false direction.
    As @Attyla.pl already said, you need to limit your range to less than 180°.
  14. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    Thank you all for the advice, it worked but I knew I had missed something... (the relationship between the gears!).
    Thanks again for the files (I'm waiting for my 3D printer for Christmas...), I found while waiting a pair of gears which should already allow me to wait for printing (no more teeth on the potentiometer side with necessarily a larger belt).
    Good simulation everyone!!!
  15. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    I just received the gear and the belt, it's great my chair remains in range for SMC3!
    Now at each start no more problems, apart from the abrupt start, I tried the SMC3 soft start 1.7a, but the data in SMC3 concerning the maximum power is not recorded? So I'm still in original SMC3, if anyone has a version other than 1.7a fixed for this bug???
    In any case, thank you guys, it’s great!
    https://zupimages.net/viewer.php?id=24/48/wyep.jpg
  16. Jodino
    Jodino New Member
    The Netherlands
    99Coins
    Hello, I am working with a 360 dgr hallsensor, combined with a 1:2 ratio. I saw you writing about smc3 works with 10bit and the sensor was 12 bit. Does this also influence the ratio? Like 1:2 x 5:6? Or what matters about the bits? Thanks!
  17. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
    I'm not a great computer expert, it must play at a level certainly but at the moment I was wrong.
    My problem came from the size of my gears, and I have not completely resolved this problem.
    I printed gears at a 1:1 ratio, but I still exceed the limits under SMC3, what seems to be a good diameter for me is gears of 4 cm in diameter (I am therefore forced to use a belt because I cannot fix my potentiometer closer to the motor axis in my assembly...).
    I will take photos to show better during the day.
  18. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    180Coins
  19. Attyla.pl
    Polska
    1,336Coins
