Question Odd noise from my 6DOF actuator
Discussion in 'DIY Motion Simulator Projects' started by SAS, Dec 1, 2024.
  1. SAS
    SAS New Member
    - 22Coins
    Hello everyone,
    I made a 6DOF based on Peacemakers build, But after I finished the build some actuators was so noisy and not the normal kind of noise, I greased the ball screw and replaced the FK12 bearing, but the noise was still there, and it coming from the area near the FK12 bearing and the motor coupler.
    Any ideas on what's causing it and how to fix it? Any help is appreciated
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hey, you have to put little grease on the red rubber connector of your coupling. Its best to disassemble it an put a tiny amount of a suitable grease (!) on the contact surfaces!
    Good luck!
    It took me two years and Llots of actuators disassembling before I could believe such a noise is comming from such a small part!
    Wickie
  3. SAS
    SAS New Member
    - 22Coins
    Thanks for replying, I ordered some silicone grease, I will grease the coupling and get back to you with the results.
  4. SAS
    SAS New Member
    - 22Coins
    OMG It worked, all that noise was from the coupling, after I greased it the noise was gone.
    Thank you so much for your help.
