2 x 50:1 mirror
Discussion in 'Forum and Website' started by Matthew Sibley, Dec 2, 2024.
  1. Matthew Sibley
    Matthew Sibley Member
    233Coins
    Hi
    I've recently managed to attach threaded rods to my 50:1 gearboxes
    With a combo of spotty welding and loctight
    The levers are set level when the power is on or off the top frame is level and the hall effect pots are fine tuned
    The problem I'm facing is the manufacturer only produces right hand gearboxes
    So when I use the free software the right side tracks along both axis where as the left side tracks ok along the x but the y seems flipped down is up and vice versa
    My question is when I purchase a license can I just flip the direction of the left motor in the software?
    I see 1 post on a thread that showed a check box for this
    Hope someone can enlighten me
    I feel I'm getting close
    Kind regards
    Maty
    148,628Coins
    +10,909 / 54 / -2
    In SimTools the Dir box being checked orange or not determines which way each axis moves, so yes you can set it in software but you can also test it with LFS.
  3. Matthew Sibley
    233Coins
    LFS ?
    148,628Coins
    +10,909 / 54 / -2
  5. Matthew Sibley
    233Coins
    Thanx so much NB
    Need to work out a better method to mount my motors as the force is more than I anticipated
    Also I had the top 2 track rod ends bolted through the back of the seat frame when I think they should be bolted in the same orientation as the bottom ones pointing in from the sides
    I'll try and post some pics soon
    Thanx again for all your support
  6. Matthew Sibley
    233Coins
    Ok so can I set axis and test the rig using the demo of sim tools or do I need to purchase a license to test
    I was under the understanding that I could use sim tools in demo mode with lfs plugin before purchasing a license
    I know the free license has been discontinued
    148,628Coins
    +10,909 / 54 / -2
    Yes you can, as per my previous comment.
  8. Matthew Sibley
    233Coins
    sorry to be a pain in the ass but i have another question
    ive set the rig up and configured it in smc 3 all good
    i cant eem to control ithe rig through simtools ill trry and post settings its the interface output values that are throwint me in interface settings in game engine
    ive been following dmax and he says copy and paste the values but from where
    ive tried to folow the gide swel and seem to be missing steps could it be to do with ip ??
    thanx for all your help i will be purchasing a license once i understand
  9. Matthew Sibley
    233Coins
    heres how far i got
  10. Matthew Sibley
    233Coins
    Also to note when I try to test output and I switch the box to on the 2nf orange light on my arduino comes on but absolutely nothing to the motors
    5 hrs reading and trying so many things but cannot get simtools to control my rig
    Works fine with smc3
  11. Matthew Sibley
    233Coins
    Wooooohoooo
    dnt know how but i got it working with lfs had to turn levels to low 20s man shes a wild beast lol
    I really wanna purchase a licese but dnt have paypal only credit card
    any suggestions buddy
    thanx for al yyour help
    148,628Coins
    +10,909 / 54 / -2
    Please see the actual SMC3 thread: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Simtools Setup
    Setup for Simtools 2 is very straight forward:
    Interface Type - Serial
    ComPort = the Arduino ComPort, you can find it in Windows Device Manager.
    BitsPerSec - 500000
    Data Bits - 8
    Parity - None
    Stop Bit -1
    Output Bit Range - 10
    Output Type - Binary
    Interface Output - [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    Also note LFS must be run before it is patched for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
  13. Matthew Sibley
    233Coins
    got it working changed usb worked in the end
    now i thingk i might have fried arduiono the signal from pot 1
    on a0 pin isnt tracking movment just showing high frequncey on the green line
    ive swaped thea0 and a1 wires and its not the pots both work on pin a1
    ill investigate further reflash ide rewire rduino l keep you posted
    thanx for all your help and patients
