Motor driver
Discussion in 'New users start here - FAQ' started by Stahlwolle, Dec 1, 2024.
  1. Stahlwolle
    Stahlwolle Member
    268Coins
    Hello, I am a new member and am looking into the topic of race simulator because I want to build one for my son. I have ordered most of the parts such as wheelchair motors and power supplies, I already own the Arduino, motor drivers and potentiometers. I came across the following motor driver on Ebay: Screenshot_20241201-220010.png
    Can someone write something about it or does anyone know if there is already a compatible Arduino sketch for two motors?
    Greetings, Thomas
  2. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,334Coins
  3. Stahlwolle
    Stahlwolle Member
    268Coins
    Oh thank you very much!!!
    I'll buy one, they seem to be really good
  4. Attyla.pl
    Polska
    1,334Coins
  5. Stahlwolle
    Stahlwolle Member
    268Coins
    Thank you very much for your help!
    I hope my 250w, 24 Volt wheelchair motors will lift my construction, with mounted pedals, chair and steeringwheel IT hast a lot of weight...
    What arm length should i use? I would try 5cm first...
  6. Attyla.pl
    Polska
    1,334Coins
  7. Stahlwolle
    Stahlwolle Member
    268Coins
    This ist my idea so far...
  8. Stahlwolle
    Stahlwolle Member
    268Coins
    Did them with my CNC, 5mm Aluminium
  9. Attyla.pl
    Polska
    1,334Coins
  10. Stahlwolle
    Stahlwolle Member
    268Coins
    I just had the same idea and milled two more. I had a friend weld something for me as an axle.
  11. Stahlwolle
    Stahlwolle Member
    268Coins
    Mounted under the seat...
  12. Stahlwolle
    Stahlwolle Member
    268Coins
    I am currently developing gears for the potentiometers.
  13. Attyla.pl
    Polska
    1,334Coins
    Are you designing gears with direct contact ?
    As in the attached picture or will the belt be between the sprockets?
    If direct, it seems that there will be too few teeth, and it will be difficult to set the level of the signal from the potentiometer/halo sensor precisely.
    My gears have 84 teeth and align perfectly:)
    :) IMG20241205215920.jpg
  14. Stahlwolle
    Stahlwolle Member
    268Coins
    I'm planning the gears with direct contact, actually the number of teeth doesn't matter as long as they mesh tightly, don't you think?
  15. Stahlwolle
    Stahlwolle Member
    268Coins
    I tried it, even the smallest rotation is transferred exactly to the other gear.
  16. Stahlwolle
    Stahlwolle Member
    268Coins
    The substructure...
  17. Stahlwolle
    Stahlwolle Member
    268Coins
    Gear holder made of aluminum.
  18. Stahlwolle
    Stahlwolle Member
    268Coins
    Today I tried everything for the first time with smc3, i used two btf7960 drivers until the 100A motor driver arrives.
    The first thing I noticed was that the right motor ran without any problems, but the left one kept failing during quick movements.
    Then, after some testingt he power supply of the left motor broke
    As recommended in the forum, I turned both power supplies down as far as possible (left motor 19,1 volts, right motor 19.6).
    Have you protected your power supplies in any way?
  19. Attyla.pl
    Polska
    1,334Coins
    Fast movements cause damage to IBT2 :) I also had another case, take off the engine cover and check if the chinaman didn't put too much grease in my case the grease got between the gear discs and somehow glued them together which caused a lot of load when the engine was moving.
  20. Stahlwolle
    Stahlwolle Member
    268Coins
    So you mean opening the motor gear? I always thought you can't grease it too much... It's not the motor driver that's broken, it didn't even get warm. The power supply is broken...
    Do you think 500 watts might be too little?
