Motor driver
Discussion in 'New users start here - FAQ' started by Stahlwolle, Dec 1, 2024.
  1. Stahlwolle
    Stahlwolle Member
    268Coins
  2. Stahlwolle
    Stahlwolle Member
    268Coins
    Maybe some interferrences because of Magnetic fields of the motors?
    The IB2 drivers dont even get warm, the engines have a lot of power...
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    That's not it, the motors should not excite themselves without information from the game, do the motors make a full turn ?
    I think Kp-500 is too much, set 300-400 this parameter is responsible for the speed of reaching the position set by the arduino and your motors have 120 rpm where most 2DOF motors use 60-80 rpm and this is enough.
  4. Stahlwolle
    Stahlwolle Member
    268Coins
    Mine have 75/min.... I'll try 300 but did before, the most direct movements I had were at 550...
  5. Stahlwolle
    Stahlwolle Member
    268Coins
    Iver tried 300 and the Same result.I can drive for a while, sometimes longer, sometimes shorter, and at some point both engines will run continuously or they will both simply stop.
    It also has nothing to do with whether the engine is under load at the time, it can happen on a straight stretch or sometimes in the menu.
  6. Stahlwolle
    Stahlwolle Member
    268Coins
    Here is a short video, again on a straight road, before that everything was working fine. It is also strange that both motors show the same behavior. There must be something wrong with the transmission to the Arduino.
    153,746Coins
    Try raising the Max Limits:
    And Fpwm at 25.
  8. Stahlwolle
    Stahlwolle Member
    268Coins
    I set fpwm to 25.
    No difference...
    If I lower the max limits the problem only gets worse, because the engines are of course switched off sooner because the limit is reached sooner
    153,746Coins
    Max Limits is set to 0 in the picture you posted:
    My suggestions are aimed at systematically establishing what I would normally expect as base SMC3 setting, before then considering SimTools settings. So can you please confirm what your Max Limits settings are.
    Then please post pictures of all your SimTools settings.
  10. Stahlwolle
    Stahlwolle Member
    268Coins
    I began with the Standards, ki,KD,KS :0
    Pwm min 0, pwm Max 0, Max Limits and clip Input 255. When i raise the Max Limits, the engines will fail even sooner.
    I'll Show you on sunday.
    153,746Coins
    As already mentioned:
    Hence it sounds like the hardware may not have adequate control and exceeds that Max Limits safety setting.
    Try lowering your Clip Limits.
    And also consider that the most effective torque utilisation is at 90 degrees and that degrades in a nonlinear manner, rapidly so after around 38-40 degrees up and down. So try and limit lever range to a max of 40 degrees up and 40 degrees down.
    What I mean is τ = r F sin(θ): https://www.omnicalculator.com/physics/torque
  12. Stahlwolle
    Stahlwolle Member
    268Coins
    Everything is great now! It was the Arduino Uno, I connected a Nano that I had lying around and I've been driving for half an hour straight without any problems
  13. Attyla.pl
    Polska
    1,336Coins
    For the information of others, show this arduino uno which was faulty
  14. Stahlwolle
    Stahlwolle Member
    268Coins
    It is an Arduino Uno clone of the brand "Leikurvo".
    What was strange was that the Unos were recognized as
    "unknown FT232R USB UART"
    under Windows despite the ch340 driver being installed.
    On one computer I had to install this UART driver manually, on another the driver was installed automatically by Windows.
    Otherwise it is a typical Chinese Uno clone without a printed company label, so visually no difference to other China Uno clones...
  15. Stahlwolle
    Stahlwolle Member
    268Coins
    I have now disguised the simulator a little and forgot to mirror the logo when milling I am expanding it directly with a drift axle...
    Do you think it is better to use two IBT2 for the front motors and the 100A controller for the drift axle or the 100A for the front and IBT2 for drift? I would have to control two Arduinos in both cases, since IBT2 runs in Mode2 and the other controller in Mode1, right?
  16. Stahlwolle
    Stahlwolle Member
    268Coins
  17. Attyla.pl
    Polska
    1,336Coins
    The 100A for the front and IBT2 for drift is better :)
  18. Stahlwolle
    Stahlwolle Member
    268Coins
    Did you connect just one power supply to the 100A controller or two?
  19. Attyla.pl
    Polska
    1,336Coins
    I connected two 24V 25A power supplies in parallel to 100A bridge, it works without any problem
  20. Attyla.pl
    Polska
    1,336Coins
