Thomson engineering s2 venture simulator
Discussion in 'Commercial Simulators and Peripherie' started by Heath, Dec 14, 2024.
  1. Heath
    Heath New Member
    54Coins
    3DOF, Motion platform
    G'day all , I've just got my hands on a commercial hydraulic motion simulator . Back in the early 2000's these things were in shopping centres and I'm looking at upgrading it with new software as a personal sim. Its running hydraulics and was hoping i may get some help .
    Thanx in advance.
    152,706Coins
    +11,092 / 56 / -2
    Most of these old arcade style motion rigs run as locked down proprietary systems.
    The first thing to do is photograph all hardware, particularly stickers with model numbers or similar identifying features.
    But don't get your hopes up, often it is easier to rip out the hardware and replace it with modern stuff that can be controlled.
  3. Heath
    Heath New Member
    54Coins
    152,706Coins
    +11,092 / 56 / -2
    Do the manuals detail the API, so that communication can be established with the hardware and control software?
  5. Heath
    Heath New Member
    54Coins
    You are correct in that the computer hardware is proprietary for the controler although my plan was to upgrade all the computer side including the driver and thought Simtools would be part of that solution. As far as the mechanical hardware goes , its all off the shelf items.
    152,706Coins
    +11,092 / 56 / -2
    What control board/code do you plan to use to interface with the likes of SimTools?
    SimTools can certainly provide the means to interface with games and construct motion profiles, but it does need to know how to 'talk' to the hardware.
  7. Heath
    Heath New Member
    54Coins
    Dunno , thats why I'm here.
  8. Heath
    Heath New Member
    54Coins
    To find out what out what options I have if any . The sim Only Cost me A$1000 and has A$10,000 worth of hydraulic gear in it so i'm not gunna loose out either way but i'm keen on making this work.
    152,706Coins
    +11,092 / 56 / -2
    Controlling proportional valves for hydraulic actuators is not impossible, and you did say you have direct experience in that area, which would be handy, but I am not aware of existing control boards/code you can easily grab to do so, though there have been historical discussions and ideas about controlling such rigs: https://www.xsimulator.net/community/threads/hydraulic-sym.9604/
    152,706Coins
    +11,092 / 56 / -2
    As an aside, if you could offload the hardware at a profit you could consider replacement AASD15A controllers:
    https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
    https://www.xsimulator.net/community/faq/motion4sim-6dof-aasd15-servo-motion-controller.392/
    And either DIY or commercial AASD15A servo powered actuators, which would likely cost way less than 10k.
  11. peter stolmeier
    peter stolmeier Member
    534Coins
    wow that looks so cool! I'd love to know more about it, did you find out it's name and serial number?
  12. Aerosmith
    Aerosmith Active Member
    self employed
    2,735Coins
    3DOF, AC motor
    There is a servo controller called R2040 from Rutex that takes step&direction signals and converts them to +/-10V velocity commands. I used them many years ago to retro-fit an old machine with analogue servo drives. Something like this can also be used to drive hydraulic proportinal valves with a Thanos controller. If you search the internet you probably find something similar based on Arduino boards that is cheaper.
  13. peter stolmeier
    534Coins
    I have a bad habit of missing obvious details. the name of the thread is what I needed to do a quick look up. It's the S2 venture and it's just as rad I thought it would be. I wish mine had those doors!
    It comes in red too!
  14. Heath
    Heath New Member
    54Coins
    Thanx for the advice, fortunately the existing driver hardware is still working and a mate who is a programer is looking into the software for the source code. The valves on the hydraulics are 24v so we will need 0-24v to operate the proportional valves. If we can get the source code then we might be able to get it to work with sim tools. Thats how i understand it anyway. we got the laser disc working today and powered up the computer and found the computer wasnt booting off the HDD. It was just making a click noise every 5 seconds so hopefuly once thats fixed we can move on to the next issue if any. we are gunna get the thing running with the software and hardware it was designed for first to get a better understanding of what will need to be changed to upgrade and repurpose the ride into a functioning 4 DOF sim.
  15. Heath
    Heath New Member
    54Coins
    heres some pics of the data plates on the valves and the motor.
  16. Aerosmith
    self employed
    2,735Coins
    3DOF, AC motor
    Ok, I can see an oil tank, the hydraulic pump, a pressure accumulator and three proportional valves. I'd check the oil and the filters first and then disconnect all the electronics. Then power the pump and see if you get some pressure. Connect a lab power supply to the solenoids one by one. If you raise the voltage from 0 to 24V you should see the cylinders moving. If the hydraulics work you can try to get the electronics running.
    I've found some info about the valves. Theese are spring centered open loop (no feedback) types. This means you don't get any information about the actual position of the plunger. It is roughly proportional to the voltage apllied but don't expect much bandwidth. You can only apply slow voltage changes otherwise the valve will overshot and cause oscillations.
    Can you see some sort of position sensor at the cylinders? There should be a glass scale or string-pulley-encoder unit for each cylinder to provide position feedback to the software.
  17. Heath
    Heath New Member
    54Coins
    All mechanical systems are working according to the previous owner. There are no oil leaks from the wiper seals or connections. Mechanicly its in great condition. Its got linear encoders on each cylinder. I cant power it up at the moment as i dont have 3 Phase power . This will be sorted as of tomorrow , I'm picking up a phase converter i got cheap.
  18. Heath
    Heath New Member
    54Coins
    Yes there are linear encoders on each Cylinder. I've been reading the manuals and found that the API is LABPAC for Dos created by Laboritory Solutions back in 1994 for there Labtender IO card which is what we have. Very basic software according to my mate and he sounds confident that he can write code for it.
    He currently has the laser disc pulled apart for cleaning as its not working well and been sitting for some 20 years. Still waiting on some parts for the 3 phase conversion. The hydraulic pump runs on 3 Phase 415V power in Delta , but we have opted to change it over to 3Phase 240V Star as i could only get a phase converter from 240 v Single to 240v 3 phase. Amps are a bit higher although the power cable to the shed is able to cope.
  19. peter stolmeier
    534Coins
    I'm new to motion simulation but media distribution is my wheelhouse. If this was my system I'd replace the laser disk with a solid state player that still connected to the SD hardware.
    I mention to make sure you've aware that's an option. It will look and feel just like the LD but with no moving parts to fail. Adding your own media would be easier that way too.
  20. Heath
    Heath New Member
    54Coins
    Yeah mate, only getting the system to run as it was built for brfore we strip it down and rebuild it with all updated gear.
