3DPGR's 6DOF build
Discussion in 'DIY Motion Simulator Projects' started by Jamie Wilson, Sep 26, 2021.
  1. Jamie Wilson
    Jamie Wilson Member
    285Coins
    After following so many amazing builds on this forum, I have decided to attempt building my own 6 DOF rig. To be used mainly for flight sims, but also racing.
    Firstly, thank you to all that have helped me get this far. I'm not one for build threads, but I'm offering my journey in the hope that it might help others along theirs.
    Here is a list of the equipment I am using.
    1610 650 ballscrews
    1019 coupler
    FK12 bearing
    80ST-M02430 220V 750W AC Servo motor and controllers
    Thanos controller
    80mm Aluminium outer tube
    50mm Stainless inner tube
    80mm Aluminium square tube
    Top bush and piston guide made from MOS2 nylon
    Ballscrew end support, 3D printed in nylon.
    Lots of nuts and bolts!
    Here is the basic design in CAD. A few dimensions have changed along the way, but its basically the same.
    The design can rotate, so I will use a clevis style joint at each end.
    I wanted to make one actuator first, to make sure everything went together and worked. (Excuse some of the bolts, these are temporary.)
    Here is the first video. Seems to work ok. Sounds a bit loud on the floor, although it isn't quiet when moving fast.
    More to come.
  2. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Haven't updated this in a while, but have been working on the rig on and off.
    Here are a few more photos.
    I had quite a few parts made in China. Quality was very good, better than I expected.
  3. Jamie Wilson
    Jamie Wilson Member
    285Coins
    I built the frame from wood to check clearances and to see if things acted as I hoped.
    • Like Like x 5
  4. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Found that there really wasn't as much room between actuator pivot points on the base as I wanted. Moving them further apart allowed for more clearance of the pedal area during yaw, and the added bonus of making it easier to enter and exit the rig.
  5. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Here area some assembly pictures of the actuators. Painted them in Audi Nardo grey.
    • Winner Winner x 3
  6. Jamie Wilson
    Jamie Wilson Member
    285Coins
    The base is made from 100x50 steel, I think 6mm thick. It's HEAVY, and I needed to make a little dolly up to move it around. :)
    I used 17mm plywood to cover the top and carpeted in marine grey.
  7. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Decided on building the top of the rig from 65mm square aluminium. Seems strong and rigid and weighs about 9kg on it's own.
    I was worried about designing with a single centre beam, and now wish I had gone with two spaced apart.
    Thinking of using a below floor joystick mechanism, but there is no room without modifications.
  8. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Some pictures of the chair. Changed from Sparco Circuit 2 to a Sparco R333. Mainly because the circuit was very restrictive when looking to the sides with VR headset on. And also difficult to work a collective on the side. Happy with the choice so far. Plus I ended up putting an adjustable slide on the bottom.
  9. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Side project is building a heli cyclic. Lucky to have my own SLS 3D printer so made the handle from nylon 12.
  10. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Another
  11. Dirty
    All the way up front.
    7,970Coins
    Hey :)
    thanks for pointing me here. Nice build!
    You have your own SLS printer and an aluminum welding machine?!? Nice! I wish I had half your toolshop. Usually, whenever family ask me what I wish for christmas, I say: "Aluminum welding machine and a CNC" :-D I wonder why I havent gotten one yet?!? ...got plenty of socks though.
    Why didn't you print those parts you got made in China (POM?) from PA12? Should be way strong enough.
    One thing I noticed: Try not to let the angle between the actuators get too pointy. Ideally you would want them to be around 90° in the standby position but that will naturally vary during motion. The pointier you have them, the less rigidity you get in surge and sway. If the angle gets too large (like >120° or so) on the other end, you might end up with less rigidity in heave.
    Here's two drastic examples:
    Very little rigidity in surge/sway
    Very little rigidity in heave
    Will follow here :)
  12. Jamie Wilson
    Jamie Wilson Member
    285Coins
    Thanks Dirty for your valuable input.
    I'm working on a revision and thanks to your Rig-O-meter, I'll move the lower points closer together. It actually shows slightly better symmetry with roll and pitch front and back.
    Cheers
    Jamie
  13. loon_NG
    loon_NG New Member
    Biot, France
    103Coins
    Hi @Jamie Wilson, thank you for sharing your work. I'm also starting to build mine. I'm in the state of collecting informations from contributors. So I made my choice for AC servo motor like yours and other contributors.
    For the actuator, I like your design but I'll mount the motor in parallel like @pooh did to gain space. I see that you use the same universal joint as @PeterW and in my thought it's the best solution. So I'd to ask you how did you get them from china? What is the material of the black joint? POM? What is the thickness of the U-shape?
    Cheers,
    loon_NG
  14. Wiley
    Wiley New Member
    22Coins
    Motion platform, 6DOF
    Hi @Jamie Wilson, I’ve been gathering information on and off to start my own 6 DOF build and had a question about linear actuators. I see some builds use a 1:1 belt and .pulley to engage the screw drive and some designs are direct drive. Why did you choose not to use a belt and go drive?
    I’m still very new to this forum and hope I’ve asked this question in the right place
    Cheers
  15. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    Direct drive:
    • easier and cheaper to build
    • more symetrical (no off-center weight)
    Belt drive:
    • Better stroke/total length ratio
    • transmission other than 1:1 possible (better torque usage for high pitch screws)
