Question Simtools 3 Min/Max settings have no effect?
Discussion in 'SimTools Pro & Entertainment Version' started by Moe Colontonio, Jan 25, 2024.
  1. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    819Coins
    Hey guys, I'm messing around with Simtools 3 with MSFS 2020. Got my profile setup, using pitch/roll velocity. The outputs are way too sensitive, but when trying to damp them down using the min/max settings, it has no effect. Only the profile intensity slider seems to work. I'm a longtime V2 user and I am familiar with how it all works.
    Thoughts?
    153,788Coins
    +11,150 / 57 / -2
    Can you please post pictures of all of your settings, including Max/Min while in the game.
  3. Richard Eaton
    Richard Eaton Member
    241Coins
    Hi, did you get this resolved, I'm suffering the same issues and there doesn't seem to be an obvious fix?
  4. Moe Colontonio
    New Jersey USA
    819Coins
    I have not had any time to mess with it.
  5. Matthew Bangerter
    Matthew Bangerter Member Gold Contributor
    Mechanical Engineer
    Mesa, AZ
    72Coins
    having the same issue with MSFS 2024 on simtools v3. Anyone find any solutions?
    153,788Coins
    +11,150 / 57 / -2
  7. Matthew Bangerter
    Mechanical Engineer
    Mesa, AZ
    72Coins
  8. Moe Colontonio
    New Jersey USA
    819Coins
    I believe my issue here was that I was adjusting "ground" min/max settings. There's a little button that shows either a road or a cloud when you click on it. I was making all my adjustments for the ground.
    I do have occasional issues with my min /max settings not saving. Can't seem to figure that one out.
