Question V2 interface plugin can`t use in V3?
Discussion in 'SimTools compatible interfaces' started by long16652, Dec 25, 2024.
  1. long16652
    long16652 New Member
    85Coins
    I'm using SimTools V2 version now, and recently I wanted to play EA Sports WRC, but I found that there is no V2 version of the game plugin. I then studied how to upgrade SimTools to V3. After downloading the software, I was stumped when it came time to set up the interface. The plugin name I used in the V2 version is NanotecC5E, and the new version V3 does not have this plugin. I searched for many articles and did not find any mention of this plugin. I don't know where to start, so please help. I've also tried to take the V2 file and install it to the V3 version, but it prompts an invalid plugin.
    plugin has upload on this page
  2. long16652
    85Coins
    150,043Coins
    +10,993 / 54 / -2
    V2 and V3 plugins are not interchangeable. Many V2 plugins have been re-implemented for V3, but not all, with work being ongoing.
    Some newly released plugins are only available for V3.
    Your best option is that V2and V3 can be installed on the same computer and can use the same license.
  4. long16652
    85Coins
    Thank you for your reply. I understand what you mean. I also installed both V2 and V3 at the same time, but the problem now is that my V3 cannot be set in the interface, so my V3 version cannot be used. I need such a plugin or corresponding configuration method.
  5. long16652
    85Coins
    I have found that the stepper motor I am using is the PD4 USB model from nanotec company. It can be directly USB connected to a PC and a virtual COM serial port can be created. However, through the V3 interface or other brands' serial port settings, it is not possible to drive the PD4 stepper motor of nanotec normally.
    150,043Coins
    +10,993 / 54 / -2
    What do you mean by:
    Can you please post pictures or give a more detailed example of what you are doing.
  7. long16652
    85Coins
    I JUST WANT TO PLAY EA SPORT WRC ON MY COMPUTER WITH SIMTOOLS V2 AND I CAN'T FIND A PLUGIN THAT WORKS FOR WRC.
    The plugins I find now are all V3, my interface is not well configured, and I can't use V3's simtools
  8. long16652
    85Coins
  9. long16652
    85Coins
    I took a closer look at it again, my device should be SCN connected, in V3, I tried the scn setting, but it still doesn't work, is there any other way?
  10. long16652
    85Coins
    150,043Coins
    +10,993 / 54 / -2
    I am sure the SimTools dev @yobuddy would be willing to give advice re setting up your rig for v3, given it works with v2, which is by far easier than someone writing a plugin for v2, which is soon to be depreciated.
  12. yobuddy
    50,045Coins
    Hi @long16652,
    We have not received an updated Nanotec interface plugin for v3 to post to the repo yet. But I believe the company does have a v3 plugin that they are handing out to customers that ask for it. I will PM you an email for the guy who helped the last Nanotec customer who asked for an interface for v3.
    Take care,
  13. long16652
    85Coins
    Thank you very much for your reply, I wrote an email this morning to the address you provided, let's look forward to his reply.
  14. long16652
    85Coins
    I received two email replies at the beginning of January, they clearly stated that they did not support simtools V3, and also recommended me a different software... It's a really sad thing
  15. long16652
    85Coins
  16. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    Hey, I'm in the same situation as you. I'm stuck on Simtools 2 because of my hardware and desperately looking for plugins for the latest games. It looks like there's no more support for it, which is really unfortunate :(
    150,043Coins
    +10,993 / 54 / -2
    It is possible for anyone, yourself included, to still write plugins for SimTools v2: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
    But the issue is the motivation to do so and more importantly the dedication to maintain plugins for a legacy version of SimTools, particularly for any game that does not provide accessible telemetry.
  18. long16652
    85Coins
    Hello, are you also using the interface nanotecC5E?
  19. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    Thank you for your response. Unfortunately, I don't think I have enough skills to write a plugin. I’m 67 years old :grin
    Very good question! Where can I find this information? When I contacted Prosimu with the serial number, they told me it was a V2 board and that I needed the new V3 board for Simtools 3. Do you think there is a way to replace this board with something cheaper? Prosimu is asking me €500 for the V3 board :(
  20. long16652
    85Coins
    I need this special plugin in my interface plugin. Then I couldn't find it in V3 version, so I couldn't use V3 version.
    The good news is that our forum expert is already modifying this plugin to V3. If your plugin is the same as mine, I can send it to you after testing and it works fine.
