FlyPT Mover 3.7.0.17
  1. lenidcamper
    lenidcamper New Member
    eastern Ontario, Canada
    64Coins
    3DOF, Arduino
    The output format template changes from 3.5 to 3.7
    SMC3 output string (decimal/ascii and actuators 10 bits)
    In Mover 3.5.2:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    In Mover 3.7.0.x:
    [A<R0.A1.B>][B<Ro.A2.B>][C<Ro.A3.B>]
    Stuart​
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    3DOF, DC motor, Arduino, 6DOF
    Ok, that's a pretty important change to know. Thanks.
  3. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    Unfortunately, it still doesn't works.
    This is the string that version 3.53 used: 091 065 001 255 093
    This is the string that version 3.7 uses: 091 065 127 255 093
    My actuator 1 goes straight up. The older version works extremely well.
    Pierre.
  4. Michail
    748Coins
    Hello flypt,
    I’ve mentioned my rig setup several times, but here’s a detailed explanation. I’m using 4 rotational motors controlled by 2 SMC3 Arduino Unos. On each Arduino, the second motor needs to be inverted. Your current rig options don’t fully fit my setup.
    Before my upgrade, I was using the DOF Reality H3 rig as reference rig in flypt mover, and it worked fine with the second motor inverted and the traction loss motor assigned to Motor 3. Now, I have one motor at each corner, with two Arduino Unos managing the system: one Arduino controls the front left motor (M1) and the front right motor (M2, inverted), while the other Arduino controls the back right motor (M3) and the back left motor (M4, inverted).
    In SimHub Motion, I select a rig configuration like the SFX-100 4-corner setup, and it works surprisingly well because it allows me to easily invert individual motors. However, I understand your program is optimized for 6DOF SFX-100 setups, and I really appreciate that. I would be grateful if you could add support for rotational motors like mine. Otherwise, I’ll have to continue compromising with SimHub.
    Thank you for your great work and support!
  5. lenidcamper
    64Coins
    3DOF, Arduino
    Did you reset the actuators to 10 bits in the rig module? (defaults to 16)​
  6. pmvcda
    15,702Coins
    Guys, just arrived home from Stocholm, will try to answer questions later.
    Sorry.
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    I looked for that option and I could not find it. Either I am looking at the wrong place or I'm looking with my eyes closed.
  8. lenidcamper
    64Coins
    3DOF, Arduino
    It is the top numeric field in the "Setup of the four feet linear actuators" pop-up form in the rig module​
  9. pmvcda
    15,702Coins
    There's some bugs on the actuators. They are corrected for the next release that I was supposed to have released already. I'm trying to solve other problems.
    But to setup the actuators you need to click the actuators drop down to show the setup window:
    This was made to reduce the amount of controls in the window and add some more...
    Depending on the rig, you might have one or more of those, for example here you get the control for 4 feet actuators, if there's one for traction loss we get another control since that actuator might use different settings while the 4 feets use the same settings.
    For now the ui is this way, but might change to a different aproach soon. Still testing...
  10. Michail
    748Coins
    Is ist possible to change from linear actuator to rotational to solve the issue I mention before?
  11. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    Indeed, after finding the parameter and set it to 10 bits, my first actuator worked as expected. But the second one (number 3) did not. Looking at the strings, it is missing data.
    Pierre.
  12. lenidcamper
    64Coins
    3DOF, Arduino
    I have not tried dual output boards, but I would think actuators 3 and 4 from R0 would be motor A and B on the second output port?​
  13. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    I will use motor A of 3 board (Arduino, Sabertooth). So, I could be using the wrong strings for my output as I have no idea what those new string means at all.
  14. lenidcamper
    64Coins
    3DOF, Arduino
    In 3.5 it seemed like a magic incantation to me. The refactoring in 3.7 suddenly made it clear. The FlyPT object model is accessible to the configurations. The format string [A<R0.A1.B>] means at run time FlyPT will substitute the Binary value of the position of Actuator 1 in Rig 0 into the output string.
    The overall sequence of the format string depends on which simulated rig actuator maps to which H-bridge driving which motor in which Arduino​
    If you select "Show the bytes in ASCII format" in the serial output module it all becomes much clearer.​
  15. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    I though that my problem with my last actuator (A3) was that I copy/paste your values and its R with the letter o instead of the number 0 (They look exactly the same with this font). But my actuator does not move (works fine with 3.5).
    Ok, the R0 is the Rig 0, the A1 is Actuator 1, but what does mean the first A(BC) and the last B?
  16. pmvcda
    15,702Coins
    B is bytes
    PBFC is position in mm or º before aplying the filtering to the actuator and cropping to limits (added for testing in the graphics) PBFC = Position Before Filtering and Cropping
    PBC is position in mm or º before aplying cropping to limits, but after filtering (added for testing in the graphics) PBC = Position Before Cropping
    P is position in mm or º
    T is turns of motor
    Also, when you change the values in actuators, the string is not automatically updated (bug).
    If connected, it's updated, but if not connected, justs change something to force the update.
  17. pmvcda
    15,702Coins
    I know the string seems more complicated, but this makes all values accessible anywhere with variables.
    It works like objects wehre you specify the rig, followed by the actuator, followed by the desired value of the actuator.
    Works like this for all the values:
    In a direct we have only oone actuator, so no need to specify the actuator: <D0.B>
    You can also output a joystick value by using vars: <J.044F040201.AY>>>>>
    Or a pose: <P0.SWAY>
    Carfull, when using ascii (old decimal), you need to specify the amount of decimal cases. For that, add more > at the end of the value. <R0.A1.P> would output 12 while <R0.A1.P>>> would output 12.45
    The number of < specifies the minimum number of digits to show before the dot: <<<<R0.A1.P>>> would output 0012.45
    This is the tooltip shown about the string:
    You can also drag and drop the values on the right inside the string to make it easier.
  18. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,031Coins
    I need to make the effort to understand it. It won't be tonight.
    So far, I don't get it and only one actuator does work with 3.7.
    3.5 works well. ;)
    I will... I will...
  19. Grucho
    Grucho Member
    232Coins
    I’ve been experimenting with the new version, and it seems very promising. I’m able to move my platform easily using absolute roll, pitch, and yaw angles. My current rig prototype can simulate 360 degrees of freedom on three axes.
    My goal is to simulate the G-forces perceived inside a plane cockpit. To achieve this, I plan to use the main axis (the external and strongest one) to generate enough centrifugal force. The other two internal axes will be used to orient the rig along the correct vector to apply the force generated by the main axis.
    I need to calculate this vector from the game data (e.g., in DCS) and then orient the rig accordingly to apply the correct G-force. However, I’m a bit stuck on how to calculate and implement the correct vector alignment. I have the math ready, I just don't know how to recall in the expression from in the filter the source data as value to do some math on top. Any advice or guidance would be greatly appreciated!
  20. pmvcda
    15,702Coins
    Kind of a fast reply...
    Why don't you use accelerations. Those are the forces felt on the plane.
    If needed, correct the pilot position in the source relative to the COG of the plane.
    Mix them on the rotations. Yaw has no mix controls, but you can always add it in the filter.
    Might be wrong and need to think better about it. Right now I'm trying to solve problems for the next update. My head is kind of exploding :confused:
