Question Multiple interfaces
Discussion in 'SimTools compatible interfaces' started by accelero, Jan 5, 2025.
  1. accelero
    accelero Member
    france
    287Coins
    2DOF, AC motor, Arduino
    Hi guys, I've got a question:
    Is it possible to use Simtools with two Com ports at the same time?
    My rig is moved by NJmotion Compact 2dof and I would like to put all the stuff on rails and power it with a linear actuator, controlled with Thanos board.
    Is it possible ?
    Happy new year everyone :grin
    153,920Coins
    +11,156 / 57 / -2
    Yes SimTools can manage multiple controllers.
  3. accelero
    accelero Member
    france
    287Coins
    :grin
  4. james wheeler
    - 143Coins
    So sim tools can handle 2 uno boards? Id like to run a 2dof and a 3dof codes off of one pc. If ao how?
    153,920Coins
    +11,156 / 57 / -2
  6. james wheeler
    - 143Coins
    Did so thank you. I also tried hooking up two computers but after a frustrating day found out that there is a difference between Ethernet cables and crossover cables.
    153,920Coins
    +11,156 / 57 / -2
    Please be aware that a 2 PC setup is redundant with SimTools v3, because of modern hardware capability.
