Showroom Another 6DOF with DC motors and encoders inspired by Fly PT
Discussion in 'DIY Motion Simulator Projects' started by Gabriel the simracer, Jan 2, 2025.
  1. Gabriel the simracer
    Gabriel the simracer Member
    - 85Coins
    3DOF, Arduino
    Hello again!
    About a year after completing my first project related to the 3DOF motion platform, I am back on the forum. It is time for the next step in creating a sim racing setup. While driving on the 3DOF platform, I could feel the lack of the additional motion axes that are present in 6DOF platforms, so I decided to build another motion platform, this time a 6DOF one.
    After many weeks of reflection and browsing the xsimulator forum, I found the 6DOF platform project by pmvcda aka Fly PT from a few years ago to be the most appealing, mainly due to the compact size of the platform and the well-documented and ready-made construction plan with a list of necessary materials.
    I also drew many ideas from various 6DOF projects presented on the xsimulator forum, and it is impossible to list them all. I admired these projects for weeks, and many hours spent browsing the forum provided me with a lot of insight into the problems and solutions related to building this type of platform.
    Special thanks to noorbeast for the tireless work put into running the forum and the very active help in solving problems, and congratulations to all the builders who are working toward the successful completion of this fantastic journey called DIY motion platform building.
    So, let's begin:
    My construction plan consists of several points:
    1. Design and Planning (a great job done by pmvcda aka Fly PT) – I refer to the thread:
      https://www.xsimulator.net/community/threads/flypt-6dof-brushless-diy-actuators.10799/
      • Schematics and technical documentation
      • Selection of components: motors, controllers, sensors
      • Selection of materials for the mechanical construction (steel, aluminum, etc.)
    2. Mechanical Construction:
      • Cutting and welding metal parts
      • Assembling the base and upper frame
      • Installing the joints
      • Mounting the electric actuators
    3. Electrical Installation:
      • Mounting the motor controllers and power supplies
      • Connecting the motors, sensors, and controller (e.g., Arduino)
      • Electrical safety tips
    4. Testing and Adjustments:
      • Testing motion in the XYZ axes and rotations
      • Troubleshooting technical issues (e.g., vibrations, inaccuracies)
      • Settings for different applications (racing simulations, aviation simulations, etc.)
  2. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    1. Design and Planning:
    After my first platform build, I had a few leftover parts that I wanted to reuse, which is why I made changes to some elements that deviate from the original plan. These are: DC 300W electric motors. Due to the size of these motors, the entire lower construction of the electric actuators was altered. The control method for these motors also changed, as they are not BLDC motors like in the FlyPT project. Instead of Hall sensors for position feedback, I will use incremental encoders. This means that the electronics and software for controlling DC motors will also change. At this point, I don't have an exact connection diagram for the control elements, but I hope it will be in the near future. For the construction of the lower and upper frame, I will use aluminum profiles according to the Fly PT project.
    I placed my first orders for the necessary parts about a month and a half ago. Some of the components I had left over from my previous platform build. Today, nearly all of the ordered items have arrived, allowing me to begin building my new 6DOF motion platform. I mainly ordered from Amazon, AliExpress, and Allegro in Poland, and some items were bought locally from stores in the town where I currently live.
    2 Mechanical Construction:
    Thanks to a few days off work during the holiday period, I was able to dedicate the entire time to this project.
    I started the build about two weeks ago by purchasing aluminum profiles from a local supplier. Since I had the opportunity to weld the aluminum profiles myself, I decided to give it a try. Unfortunately, after several hours of attempts, I was not satisfied with the results. I could not achieve a good weld fusion at the joints. Below are a few photos of this "tragedy."
    20241218_153109.jpg 20241220_132422.jpg 20241220_133934.jpg 20241220_133937.jpg Welding aluminum with a coated electrode is not an easy process. After several hours of trial and error, the key to success turned out to be heating the material to around 150°C. This allowed for a good fusion of the material at the joining points.
    But for now, I skipped the part with welding aluminum because I already had parts for building the electric actuators, and this work gave me a lot of satisfaction.
    In the meantime, the 3D printer worked several hours a day for about two weeks to deliver the needed parts.
    So, the actuator construction has begun:
    I had to disassemble the gearboxes from the motors I had and prepare the motors for assembly.
    And I started by welding the actuator bases,
    20241230_111826.jpg 20241230_111840.jpg 20241230_111908.jpg 20241230_113249.jpg 20241230_113259.jpg 20241230_113327.jpg 20241230_124021.jpg
    measuring, and drilling numerous holes in the plates for motor mounting. To the upper plate, I welded threaded rods for mounting the SFU 1605 screw.
    20241222_113051.jpg 20241227_125750.jpg 20241227_153611.jpg 20241228_134245.jpg 20241230_094316.jpg 20241230_101045.jpg
  3. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    Stick welding aluminium? Wow, I didn't know that this was possible at all. We tried MIG welding last week but it didn't work at all. The wire buckled up several times inside the tube and although both workpieces melted the two puddles never joined. The DC arc couldn't break the oxide layer. So we had to give up and ordered an AC TIG welding machine. With the professional welding machine of another friend the results looked pretty well. I hope we'll get at least somehow acceptable results with the cheaper hobby machine we ordered...
  4. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    It's possible, but not easy as it turned out. Heating the material helped to break through the oxides. I managed to weld the lower frame, but I have concerns about the upper frame, as the weld might be too shallow, so I'll probably take it to someone with a TIG welder to ensure the best possible quality of the joint. I estimate that the strength of the welds on the lower frame is at most 30-40% compared to aluminum of the same thickness. I also considered trying MIG welding, but I didn't have aluminum wire for that welder at the workshop. The lower frame welds don't experience any significant forces, so I'm not worried about their strength, but the upper frame needs to be welded properly.
  5. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    Construction continued...
    The next step is to attach the upper joints to the 24mm inner diameter aluminum tube of the linear actuator. It turned out that 17mm socket wrenches fit perfectly, and I placed a washer as a movement limiter between the socket and the cross joint and then I welded the socket and the cross joint together . I also welded a 12mm bolt into the cross joint.
    The next step is to attach the upper joints to the 24mm inner diameter aluminum tube of the linear actuator. It turned out that 17mm socket wrenches fit perfectly, and I placed a washer as a movement limiter between the socket and the cross joint. I also welded a 12mm bolt into the cross joint.
    Through the aluminum tube and the socket pressed into it, I drilled a hole and installed a spring pin. So, everything looks solid and strong.
    20241230_130712.jpg 20241230_130742.jpg 20250102_133138.jpg 20250102_135256.jpg 20250102_141213.jpg 20250102_141718.jpg 20250102_141923.jpg
    Next, I cut the threaded rods and aluminum tubes to the appropriate lengths to serve as mounting bolts for the motors. Unfortunately, I don't have any photos from this process.
    It has come time to make thread to aluminium profiles too.
    It went fast with 5mm tap and screwdriver.
    So, everything was ready for mounting my very first linear actuator.:)
  6. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    Finally time to mount Actuators together!!!:):):)
    Part 1
    And Part 2.
  7. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    Here is the video from first test of movement. I used two Arduinos, one is changing encoder digital signal through DAC converter to analog 0-5 V output. So, another Arduino see the signal exactly like from potentiometer. So, no changes in software smc3 for testing made. Finally version i think will work on one ESP32 for encoders signal conversion and 3 arduinos or maybe 2 ESP32 , not decided yet.
  8. Qui
    Qui New Member
    - 154Coins
    The project is worth looking forward to.
  9. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    In the meantime, an update regarding the lower supporting frame,
    and I managed to assemble all the linear actuators.
    The second stage of my project has to wait a bit for the upper frame, but I can now move on to stage 3 and focus on assembling the electronics.
  10. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    Stage 3: Electrical Installation
    Over the past few weeks, I managed to find some time to move the construction forward. I don’t have experience with the ESP32, but my idea was to use two ESP32 modules along with logic level converters and DAC converters in such a way that the signals from the encoders would be converted into an analog signal of 0-5V. 20250118_111806.jpg
    If successful, I would have obtained a 12-bit signal with 4096 possible analog signal levels. However, I got stuck at the programming stage, as I don't have experience in this area. I assigned the task of programming to the GPT chat. Unfortunately, at some point, I couldn’t find the error in the construction itself and suspected it was something with the software.
    Since I also ordered parts for a simpler version with an 8-bit signal with 256 positions for the analog signal between 0 and 5V, I decided to build the simpler version on two Arduino Nano clones by converting the program to Arduino. After a few code changes with the GPT chat, the clones started sending the expected signal. Now I can say that an 8-bit signal is perfectly sufficient for this project. Furthermore, the main motor control relied on three Arduino Uno clones with the SMC3 software unchanged and 100A Chinese motor drivers recommended on the forum by several users.
    All that was left was to assemble all the electronics onto one board and order a server rack for the control system and power supplies. After a few evenings spent on the electronics and software, and after receiving the server rack, I was able to place everything inside.
    In the meantime, I managed to transport the lower load-bearing frame to my home, and on that day, I was able to initially mount the actuators.
    The following days allowed me to wire the actuators and assemble the control electronics.
    The electric motors are equipped with electromagnetic brakes, which can also be turned off mechanically if needed, so there were quite a few wires.
    Everything looks promising as far!
  11. Josh Latka
    Josh Latka New Member
    102Coins
    Aluminum needs to be clean! MiG welding alum works best with a push pull machine but can be done well with a spool gun. If wire is backing up and making a birds nest in the spoiler it needs to be tuned and your weld settings need adjusting
    Also when mig welding alum it’s essential to push the weld and don’t drag and have a good angle with the gun. A push pull can be set to pulse also
    For the best results tig welding alum will provide the best results and get the best penetration. I’ve welded alum for years and never pre heat it unless it’s 3/4 or thicker. Also the gas used will have a big impact. Alum works best with 100 argon or a min of 90/10 argon. Your standard mig gas for steel will not yield good results.
    I’ve only used stick to weld alum in a situation where the project was outside and not able to be moved into a shop. Alum will not flow if gas is not present.
  12. sci666
    1,210Coins
    wow looks good !!! can you tell me what motors you have and what ballscrew size it ist and what pitch ? 10mm ?
    theres no information about taht in your post. iam planning to switch my rotary actuators to some linear ones with all the existing Motors and stuff ....
    so you dont use any gearbox so direkt motor to ballscrew connection ... thats why i ask about the motor :) Volts, Watts, rpm ?
  13. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    Hey, thanks for the post. I'm using SFU 1605 screws, 500mm long with a 5mm pitch. They're a bit noisy, but you can manage with headphones. After the first tests, it seems that they're sufficient, but I feel like trying out SFU 1610 because many people say they're quieter and twice as fast in operation. I haven't had time for more tests recently, but I hope to finish this project soon.
    As for the motors, they are from Permobil wheelchair motors, model Leroy Somer MBT1101xvs, 300W power, 22V voltage, with a rotational speed of 2900 rpm. The screws are mounted directly to the motors without any gearbox.
    Here is the last test I managed to do.
    https://www.youtube.com/shorts/5m6-ei2Bbhs
  14. sci666
    1,210Coins
    ok cool :) i consult my chatpgt pro account a bit about this :) it seems that for 1610 the motors are a bit weak for a direkt motor to ballscrew connection. the 3000rpm motor to 1605 ball screws are theoretically "high speed" as is!!! with your 1605 you have already 250mm/sec which is very high! with 1610 is will be 500/sec ... thats way to much i think a sim can handle it will not work properly, you reduce also the torq of the system.
    i have 24V 350Watt Motors in my rotary 6DOF System with a bit less torq then the small ones from the building link you posted - these motors from the link has "only" 220 watt but have some more torq so they are sufficient.
    i will do a prototype of my motor with SFU1605 like the ones from the link. chatgpt calculates some stuff and say it will work and have enough reserves for all the inertia forces.
  15. sci666
    1,210Coins
    ah an additional question. do you use the motor brakes to prevent sagging down if the system is turned off ? its not self locking right ? is that a problem or still ognoring it because its not necessary if the rig comes down if off.
  16. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    A 300W motor coupled 1:1 to a 10mm pitch ballscrew generates only 500N thrust. If everything is symetrical (heave, 6 motors parallel) this is fairly enough (3000N can lift 300kg). In extreme roll or pitch positions the forces can go up to about twice the normal load. So if your rig weights below 150kg and you have some headroom in the current capacity of the drivers for short term overloads (acceleration) then it should work OK.
  17. sci666
    1,210Coins
    maybe :) i used intensively chatgpt for some calculations .... for example i have 350 watt motors with about 1.2 Nm torq.
    and almoust 3000rpm (24V)
    with 1605 ballscrew its able to move 150KG reliable. (very fast 250mm/sec) with 1610 it drops under 100kg theoretially unbelievable fast speed with 500mm/sec. (in my opinion absolute not necessary) and also - i call it the force savety reserve decrease massively
    (about the speeds - for example the consumer prosimu acuators has 280mm/sec)
    chatgpt say that its possible but with optimal conditions , you should tweak the system to the optimum and set movement limits and so on etc to not go over the top. (and chatgpt works only with the theoretical numbers - and you know in real life everything is different + murphys law you know ;D
    so in general it should be possible but to be save i would stick to the 1605 ballscrews.
  18. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    What most people and most likely ChatGPT also don't know: with 1605 ball screws you need more energy to accelerate the rotational inertia than you need to move the rig. Read this: Auslegung von Kugelrollspindeln. (German, but no problem for you, I assume) At least until post #43 where it gets interesting about ratio of motor:load inertia and gear ratio. DC motors usually have a much higher inertia than brushless motors.
    You also have to take into account that the motor runs near its RPM limit at 250mm/s with 5mm pitch. This is not only bad for the ball nut but also means there is no headroom for the motor voltage vs. supply voltage. If the back EMF voltage is almost as high as the supply you have no reserve for overload and fast acceleration. This means it tends to lag behind especially if the movement is jerky and not smooth. Any lag tends to saturate the PID loop of the controller and means more current, stress, vibration, overshoot and so on.
    So I'd bet the motor runs much better with 10mm pitch if you limit the max. speed well below 500mm/s and your driver and power supply can withstand twice the rated motor current.
  19. sci666
    1,210Coins
    good point ;) i think i test both when i build 1 actuator for "research" one with 1605 and one with 1610.
  20. Gabriel the simracer
    - 85Coins
    3DOF, Arduino
    ChatGPT is a great tool; it helped me immensely with the software for my rig, as I have no experience in programming myself. Although it sometimes makes mistakes, I am still impressed with the information it can provide. As for the SFU screws, you might be right that they are more than enough for the simulator, after all, it’s not a catapult simulator:grin. DC motors have the highest torque at low speeds, which decreases as the rotational speed increases, so I think that with the right settings, they would also handle SFU 1610 screws, and apparently, they are much quieter in operation. For now, however, I will stick with SFU 1605 until the simulator is completed, though I might revisit the idea of changing the screws in the future. As for my DC motors, there is very little information about them online, so I’m not 100% sure about anything. I’m building it somewhat through trial and error, and only the tests of the finished simulator will show if they are truly sufficient.
    And about brakes on the DC motors, yes I will use it, but for now I have open it just for test, they will lock the actuators when emergency button activate. When the are open actuators retract to its down position. As after first tests they need quite a lot energy to keep them open, around 150W, when all motors during tests took only 300W peak power with 230V.
