Question Game Plugins..
Discussion in 'SimTools DIY Version' started by EugenioB, Jan 12, 2025.
  1. EugenioB
    EugenioB New Member
    - 12Coins
    Hi! I'm building my first 2 dof motion rig... My question is: the games plugins only work with steam?? because I have msfs2020 and msfs 2024 both on xbox games app... is there some way to run them? thank you
    153,890Coins
    +11,154 / 57 / -2
    Consoles are a bit different, and normally need their own plugin plus communication process as SimTools is PC based, see the FAQs here: https://www.xsimulator.net/community/faq/consoles.27/category
    With a PC version of a game the launcher can normally be dragged to SimTools v3 interface to use it, instead of a Steam version of the same game.
  3. EugenioB
    EugenioB New Member
    - 12Coins
    thank you! .. yes i'm on pc... how can I drag the launcher?
  4. yobuddy
    51,536Coins
    The plugins default to steam, but every effort is made it make them work with all versions of the game.
    After the plugin for the xbox app games get installed, you will simply need to update the launch path for the games in SimTools v3. To do this, simply drag-drop the shortcut for the game onto the game banner in SimTools v3. Now when you launch the game from SimTools, it will launch your version of the game (and not look for the steam version).
  5. EugenioB
    EugenioB New Member
    - 12Coins
    ahh great! thank you so much guys
  6. Gracee
    Gracee New Member
    34Coins
    Thanks so much for the helpful information on using SimTools with PC games. I will look into it and hopefully find a way to integrate MSFS2020 and MSFS2024 into my system!
    153,890Coins
    +11,154 / 57 / -2
    SimTools v3 Beta has plugins for both MSFS2020 and MSFS2024: https://simtools.us/plugin_library/
  8. Henjamin
    Henjamin New Member
    34Coins
    DC motor
    I'm also currently setting up my first 2 DOF motion rig as well. My question is: are the game plugins compatible only with Steam, or can they also work with titles available on the Epic Games Store? I have some games there that I’d love to use with my rig. Thanks for your help!
    153,890Coins
    +11,154 / 57 / -2
    Being new you should use SimTools 3 with the new plugin repository, and you can set a game launch path, simply drag and drop the games exe or shortcut on the banner for the given game plugin.: https://xsimulator.net/community/faq/simtools-v3.401/
  10. Henjamin
    Henjamin New Member
    34Coins
    DC motor
    Thank you
  11. Henjamin
    Henjamin New Member
    34Coins
    DC motor
    I will use SimTools 3!
