Question Horse DOF simulator
Discussion in 'Off Topic - All other stuff here' started by Tom Bia, Jan 11, 2025.
  1. Tom Bia
    Tom Bia New Member
    45Coins
    Hello, I’m planning to build a DOF platform for a horse riding simulator (walk, trot, canter). If anyone could share any suggestions, I would greatly appreciate it. Thank you.
    152,559Coins
    +11,087 / 56 / -2
    I am not aware of any past horse simulator, however I would suggest you study @Chris_Beeves motorcycle rig, as there are some shared key challenges for a rig designed for a rider: https://www.xsimulator.net/community/threads/motorcycle-4-dof-motion-sim.16530/
    Also check out the use of pneumatic bladders often used in G-Seats, given a horse is not a rigid object: https://www.xsimulator.net/community/faq/gseat.20/category
    There is also the question of what it would be used with and required telemetry: https://www.xsimulator.net/communit...in-for-simtools-v3-0-api-documentation.17019/
    If it is an existing horse game then perhaps the devs can implement the required output, if using Unity or Unreal Engine: https://www.xsimulator.net/communit...ry-output-into-a-game-unity-and-ue4-code.287/
  3. Tom Bia
    Tom Bia New Member
    45Coins
    Thank you for your quick response! I will check out the links.
  4. accelero
    accelero Member
    france
    207Coins
    2DOF, AC motor, Arduino
    I' ve been working on it for several years ( part time)
    I have built one, based on a 2 dof platform at the moment, planning to scale it to 4 dof and perhaps 6 dof.
    The main thing I' ve been working on is software because using accelerometer data is tricky, you have to clean the data a lot to get something good, it's time consuming .....
    So the solution I've found is programming walk , trot and canter on my computer and send data to my platform,
    of course a game designer could include this telemetry in a 3D game, should be perfect :)
  5. Chris_Beeves
    2,097Coins
    Is there any horse riding software with telemetry output (or without for that matter..)? I imagine Red Dead Redemption would be dreamy if you could extract the motion.
    I’d go at least 3dof for a horse sim. Heave/Pitch/Roll in my mind should go a long way. In order to make proper use of surge, sway and yaw, you’d need some seriously advanced simulation software.
  6. Tom Bia
    Tom Bia New Member
    45Coins
    My intention is simply to create a training device with three horse gaits, without VR or TV screens. Would you mind sharing some photos of your platform?
  7. accelero
    accelero Member
    france
    207Coins
    here it is .
    One attempt was to use data from accelerometer on horse girth. VideoRideCreator is a nice stuff to do so. Playing the stuff in videoRidePayer is fun !
    But as I said, most of movements recorded by accelerometer seem to be irrelevant on a simulator, too noisy, So
    cleaning the data is a lot of work:Fourier transform and so on .......
  8. Tom Bia
    Tom Bia New Member
    45Coins
    Thank you for sharing!
  9. Tom Bia
    Tom Bia New Member
    45Coins
    I’ve identified two common platform designs: linear actuators and servo motors with gearheads. Which would be the better solution for a horse simulator? I anticipate a maximum movement range of 6 to 10 inches, with an estimated total weight (including both the child rider and the horse model) of approximately 200 lbs.
  10. Chris_Beeves
    2,097Coins
    I started with worm gear motors, the dofReality type. They are power hungry, noisy and have backlash.
    I upgraded to eracinglabs rsmega actuators and it’s a whole new world. Would never choose gearbox motors again if budget didn’t force me.
