FlyPT Mover 3.7.0.9
  1. Grucho
    Grucho Member
    232Coins
    Thanks for the quick reply. I will try and let you know. Meanwhile if you come up with a solution let me know. Cheeeeeers!
  2. michel123
    michel123 Member
    cadre sncf
    lezignan-corbieres
    188Coins
    One step after the other, and at the end of the day we can measure the distance traveled, not before....
    Good luck, you always have our full support!
    Happy New Year and best wishes to you and your family!
  3. Chad Hamilton
    Chad Hamilton New Member Gold Contributor
    4Coins
    Have you been able to make the simtools plugin for flypt yet for simtools v3 that is?
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    3DOF, DC motor, Arduino, 6DOF
    I've tried to understand the new strings:
    [A<R0.A1.B>]
    Please Axis 1, send your data to Rig 0, Actuator 1
    it works.
    [C<R0.A3.B>]
    Please Axis 3, send your data to Rig 0, Actuator 3
    Does not work.
    I have a 3 actuators rig, 1 and 3 are up front. If I switch the COM PORT, the other actuator start to move. I see the data changing on both output and they have the connection arrow in mover main window.
    Is it a bug or am I missing something?
  5. Fors
    Fors New Member
    16Coins
    Try [A<R0.A3.B>] or [B<R0.A3.B>]
  6. pmvcda
    15,372Coins
    How many controllers are you using? And what controller?
    Because for a 3DOF rig using one SMC controller you need:
    [A<R0.A1.B>][B<Ro.A2.B>][C<Ro.A3.B>]
    If you are using two controllers, one for each side, connected in different ports, are you sure one is #1 and the other #3? They might be both number 1 and for that you need two outputs, one for each usb port:
    [A<R0.A1.B>]
    [A<R0.A3.B>]
    But this would be strange...
    More info here: https://www.xsimulator.net/community/threads/flypt-mover-3-7-0-9.19016/page-21#post-251484
  7. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    Ok, I got it.
    [A<R0.A1.B>] Front Right (com3 for me)
    [A<R0.A2.B>] Back (com4 for me)
    [A<R0.A3.B>] Front Left (com 5 for me)
    I use 3 arduino with 3 Sabertooth and each motor is connected to output A of each Sabertooth.
    Thanks for all the help.
    Pierre.
  8. pmvcda
    15,372Coins
    Soon:
    Some directions seem wrong...
    Data seems to have a good resolution (frequency);
  9. TheTakerPL
    TheTakerPL New Member
    34Coins
    Hi, I have a question:
    I'm preparing to build 6DOF rig for DCS world using Mover, and I want to have some specific telemetry data exported from the game, which I cannot find in any Mover's list.
    I need to somehow get "LoGetShakeAmplitude()" value used for helicopters vibration during VRS, ETL, etc.
    Is it possible to add this value to the list by editing some config files or I need to make custom source?
  10. TheTakerPL
    34Coins
    Also I need to add that value is read correctly in FFBeast Forcefeedback joystick which I have built - so it's possible to get it.
  11. pmvcda
    15,372Coins
    I will take a look. You can always replace one of the lua values by that one, but will try to add it on the next release.
  12. TheTakerPL
    34Coins
    Thank you. I just was about to write, that - for a temporary solution I can replace some unused value in "DCS_To_FlyPT_Mover.lua". I just need to find something not needed :D
  13. Onkel
    Onkel New Member
    2Coins
    Have anyone had any luck transferring DoF H6/P6 from 3.5.3 to 3.7.0?
    With the (seemingly) same settings platform stucks on the motor limit and tries to go beyond it.
    Outputs converted as per guide.
  14. John Doe 77
    John Doe 77 New Member
    Hanau / Germany
    34Coins
    Hello to the group. My name is Jörn and I have built a 6 DOF linear hexapod simulator. Are there ready-made profiles for the various simulations for the current Flypt Mover software?
    Thanks for the feedback and have a nice weekend!
  15. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,101Coins
    In version 3.5.3 if you right click and select olnilne files you will find several profiles
  16. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    In that video:
    I was able to make Elite Dangerous work with Simtools, but not with Mover.
    It did move somehow for a while, then I could not get any values from the source.
    Is it working for Elite? Do I have to do something special?
    Thank you.
  17. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    4,964Coins
    @pmvcda I have updated the github xml file.
    I don't know if mover is seeking it automatically or not.
  18. Marco Annunziata
    847Coins
    Has someone tested the MAXACCEL function? Do you get strange behaviors, like crazy movements, or is it normal?
