Possibilities of a 6dof with 6 (SCN6-040-300)?
Discussion in 'Off Topic - All other stuff here' started by yobuddy, Aug 8, 2010.
  1. yobuddy
    51,194Coins
    I know it’s expensive but what 6dof isn’t?
    They produce 40kgf (about 88lbs) with a speed of 200mms
    That makes a platform capable of carrying (`528 lbs). Or 240kgf!
    We already can control them with x-sim and we know they work well.
    And this thing would be really fast compared to some of the other 6dof platforms.
    I'd offset the riders & platform weight with 6 - 20 to 35lbs springs.
    What do you guys think?
  2. Frakk
    Frakk Active Member
    328Coins
    I don't have experience with the actuators but from what I gathered, you cannot put much lateral force on them or twist the output shaft, otherwise they will brake. Putting them in a hex 6dof geometry would do just that.
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    Afaik, Nima is going to try this. However, I dont know how he is progressing.
    Regards
  4. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    I have a variety of approaches to this here as well. It is too early to tell which design will work out the best.
  5. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    i mean the scn6 with 40 kg and a not to big drivers are work without springs.i have work with a other guy on a rock and ride with scn6 40kg and hi work so powerfull .and with the scn, my profil idea for 6 dof are work best.you can build a 6 dof and
    than you mesurge after work with the potis in the scn6 all positions. than it is not
    a problem with a not perfect sim building.
  6. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,797Coins
    Hi Nima are you realy shure ,a stuward platform will work with 6 x 40kgf ?
    If so youre making my day.
    regards Ad
  7. Nima
    Glaser
    Bad Zwischenahn
    532Coins
    hi,
    with a spring system i am shure.without springs you must have the weight over all (seat driver wheel
    paddels) under ca 100kg or you must make doppel scn6 on all 6 places.but a spring system is the best way with scn6 and a 6 dof.
  8. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,797Coins
    Hi Nima
    Thanks for youre reply.
    I am thinking about 48volt servo,s without springs(Thanos way)
    The scn6 40/300 force speed curve is dropping fast,i think a dof6 will be very slow
    with steppers it,s force against wight ,without springs
    i hope youre not gone waste a lot of money ,and make a nice dof 6
    best regards Ad
  9. yobuddy
    51,194Coins
    This should take most of the strain off of the SCN6 actuator.
  10. Frakk
    Frakk Active Member
    328Coins
    This is a good start for making the actuators much stronger!
    The only problem I see here is the mechanical implementation of the whole platform. The actuator is way too long, about 60-70cm from joint-to-joint with a travel of only 15cm. This is obviously not optimal for a standard hex 6DOF platform because it would be very large, with relatively small actuator movement.
    I think it is very doable with enough optimization of the geometry and sizes.
  11. yobuddy
    51,194Coins
    15cm? the actuators are 300mm??
    about 12 of movement i believe.
  12. Frakk
    Frakk Active Member
    328Coins
    Yes, sorry. My mind was on SCN5's.
