need help with 2 dof
Discussion in 'Ready, set, go - Start your engines' started by kai, Jan 23, 2025.
  1. kai
    kai New Member
    124Coins
    what are some good motors 24V 3A for $100 aus dollar
  2. kai
    kai New Member
    124Coins
    and also my 10 k potentiometers seem to not be linear instead of 12345678910 it seems to be 1 2 4 8 16
    153,938Coins
    +11,158 / 57 / -2
    Please detail the rig you intend building, as design Vs physics tradeoffs greatly influence motor choice and placement, tools like SimCalc can help: https://www.xsimulator.net/communit...e-linear-speed-and-forces-of-your-design.270/
    Please be clearer about the issue and what you have or have not done in whatever context, as none of that is clear just yet.
  4. Joe Cortexian
    1,549Coins
    24V 3A is 75 watts. That’s not enough power to effectively move a rig. Some are more efficient than others but set your sites on 6-10 amps. Often you don’t see torque in the motor spec but if you do think 30-40nM at least if most of the weight of your rig is on a Ujoint.
  5. kai
    kai New Member
    124Coins
    are these good
    153,938Coins
    +11,158 / 57 / -2
    Those are going to be about twice your stated budget of $100 aus dollar, and if outside the USA you need to also consider shipping.
    If you are looking for budget friendly but still powerful options then consider 24v wheelchair motors, which are available new and secondhand.
  7. kai
    kai New Member
    124Coins
    sorry i meant 100 each and but are those ones good that i sent ?? and also what about to potentiometer problen that i stated
    153,938Coins
    +11,158 / 57 / -2
    Coming back to my earlier comment, before you get too deep on hardware you need to clearly define the design:
  9. kai
    kai New Member
    124Coins
    ive already made the whole thing
    153,938Coins
    +11,158 / 57 / -2
    Please post some pictures so we understand what the design is.
  11. Joe Cortexian
    1,549Coins
  12. kai
    kai New Member
    124Coins
    there you go
  13. noorbeast
    153,938Coins
    +11,158 / 57 / -2
    Nice job :thumbs
    I am curious about the specs of the motors wrapped in plastic?
  14. kai
    kai New Member
    124Coins
    they are the reason im here there not powerful enough they have more torque in one direction than the other and their only 2 a 45 watt 24v
    153,938Coins
    +11,158 / 57 / -2
    In that case may I suggest you can at some point in the future perhaps repurpose the use of your existing motors for a telemetry driven race harness: https://xsimulator.net/community/faq/harness-tensioner-simulation.361/
    Depending on where you are in the world I suspect secondhand or new 24v wheelchair motors are likely an economical choice, given your existing foot mount design.
    But given you mentioned $AU, if I presume you are an Aussie, then we have Motion Dynamics as a reputable and convenient local DC motor supplier: https://www.motiondynamics.com.au/
  16. kai
    kai New Member
    124Coins
    ok cool so wheelchair motors
    what amount of torque do i need ?
    153,938Coins
    +11,158 / 57 / -2
    Please see my earlier reply:
    That said, you did not clarify where in the world you are located, as that greatly influences what is available at what cost!
  18. kai
    kai New Member
    124Coins
    im in australia
    153,938Coins
    +11,158 / 57 / -2
  20. kai
    kai New Member
    124Coins
    i got some motors from a mate and he works on electric wheelchairs they are heafty!!!!
