Question 2dof compact build. Motor question
Discussion in 'DIY Motion Simulator Projects' started by Michael Yoshi, Jan 28, 2025.
  1. Michael Yoshi
    Michael Yoshi New Member
    95Coins
    So far my build is:
    These motors
    2 BTS7960 drivers
    Random Arduino mega I have lying around
    1 600 Watt power supply
    Random potentiometers I have lying around.
    Ujoint from an old drive shaft I have
    First question - Are those motors quick enough for a basic 2DOF?
    Second question - Any tips for a compact build? My general thought is a 2.5ftx3.5ft rectangle top and bottom. I have a welder but I'm in an apartment like area so grinders and such are a bit much.
  2. Michael Yoshi
    95Coins
    75rpm seems low but I'm not aming for a ton of movement.
  3. Joe Cortexian
    1,039Coins
    My motors are 36RPM and I don’t have any complaints. The lower RPM gives you more torque for the same power.
    SMC3 was designed for Uno. It doesn’t do much abstraction. I know it won’t compile on Leonardo due to the way that it sets up PWM on pins which are not PWM pins by default. Mega I don’t know for sure. You can always buy an Uno if it doesn’t work.
  4. Michael Yoshi
    95Coins
    Good to know the motors look like they'll work. Since I'm working in a compact space, more torque makes sense. Was a bit worried one power supply wouldn't be enough.
    And yea, I have a drawer full of different arduinos. One of them will work lol.
  5. Joe Cortexian
    1,039Coins
    Your PSU will work but when I upgraded from under spec to over spec it worked better. This meant I had to dial down the output in some cases. I think my original PSU was only 360w.
  6. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,332Coins
    Power supply 1 piece for 2 motors 24V 13,4A 75rpm will be too weak , you need one power supply for one motor. these motors can draw up to 20A maximum.
    If you are looking for a compact design for a car simulator see this one
    https://www.xsimulator.net/community/threads/diy-3-dof-inspired-by-dof-reality-h3-model.18273/
    IBT2 bridges are too weak for these motors ( I tested, burned 8 pieces )
    Better use this 100A controller
    https://www.xsimulator.net/community/threads/reasonably-priced-100a-motor-controllers.17638/
    ( I tested , it works smoothly in mode 1)
  7. Joe Cortexian
    1,039Coins
    24v x 40amps = 960w. I don’t see a problem. 1200w power supplies are common.
  8. Michael Yoshi
    95Coins
    Thanks for the info. I really don't want to reinvent the wheel. I'm just looking for what works. Taht's why I got the IBT2s. I am having an issue where quick movements seems to shut off the power supply for a second. I thought it was because it was one power supply for 2 motors but even if it's just one, it does it too. Gonna guess the power supply isn't enough. But I found it on another build so I'm curious as to why I'm just having the issue.
  9. Joe Cortexian
    1,039Coins
    I was in a similar situation with a third traction loss axis. I don’t know much more than you about a solution but I suspect that the motor and the ibt2 just didn’t get along. The symptom sounds similar.
    I tried a more expensive driver but unfortunately it self destructed after a few minutes of operation. I got my money back and have moved on. Others on this forum recommend this solution.
    https://www.aliexpress.com/item/1005005949153753.html
    Are you sure the Arduino is still running? I added code to the main loop to flash an LED which will stop if the CPU goes away.
  10. Michael Yoshi
    95Coins
    I ordered the 100a driver that seems to be going around. Looks like people are having good luck with it. Also got a second PSU and 2 capacitors to try to keep it from dipping too hard. I like your idea of the LED to verify. The SMC tester thing doesn't seem to lose connection though but it's always nice to have a visual.
  11. Michael Yoshi
    95Coins
    Well I went down a chatGPT hole and it suggested these 63v capacitors. It says to wire them in parallel just before the driver for each power supply. But looking around, I don't see anyone else here that's done this. Is GPT hallucinating?
