2 dof with ibt 2 and smc 3 problems
Discussion in 'DIY Motion Simulator Projects' started by dope-walker, Jul 14, 2021.
  1. titofe
    titofe Member
    642Coins
    2DOF, Arduino, SimforceGT, Motion platform
    hello it will not be better to go on a Sabertooth Controller 2x32A 6V-24V, I no longer have the possibility of testing a card like this one, are there Arduino codes, I no longer use the iBT 2. please let me know if there are any paths to take, thank you friends
    153,914Coins
    +11,156 / 57 / -2
    When you say you lost everything what was it that you did and what specifically is the issue.
  3. titofe
    titofe Member
    642Coins
    hello when I say I have lost everything it is because even the first motor adjustment it no longer works it turns without stopping the green line on the potentiometer goes up it goes down it does not stop the engine between the red lines. I changed the two ibt 2 cards they are brand new the settings they do not take as soon as the engine turns the green potonciometer line it goes up quickly outside the red lines. Smc3 I reset everything to zero I started everything there is nothing that takes it's strange. I'm going to change my Arduino card. Thank you
  4. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    It is thought that you should use a typical Arduino Uno R3 board.
  5. titofe
    titofe Member
    642Coins
  6. titofe
    titofe Member
    642Coins
    It won't be better a Sabertooth Controller 2x32A 6V-24V card. Thank you
  7. Attyla.pl
    Polska
    1,336Coins
    It depends, in principle with a 12V motor power supply the IBT2 bridges should work correctly , unless their quality has already declined so much that the new ones are already damaged. If I were you, I would buy an Arduino and once again calmly and slowly connect everything, it should work properly.
  8. titofe
    titofe Member
    642Coins
    understand what you're telling me, that's already 4 iBT 2 losing Arduino cards. the motors are 24 volts 160 w I lowered the power supply to 18 volts. I have the possibility of testing with a Sabertooth Controller 2x32A 6V-24V card, it will be better for both motors no what do you think Thank you.
  9. Attyla.pl
    Polska
    1,336Coins
    If you use 24V motors then you can use the controller from this thread without any problems:
    https://www.xsimulator.net/community/threads/reasonably-priced-100a-motor-controllers.17638/
    I use it myself, last week I built a 2DOF for a friend on such controllers and it worked without any problem .
    One note recently a colleague pointed out to me that the 100A driver bought on ebay platform had slightly better build quality than the same one bought on aliexpress. Although I bought on both platforms and so far they all work.
  10. titofe
    titofe Member
    642Coins
  11. titofe
    titofe Member
    642Coins
  12. titofe
    titofe Member
    642Coins
    I posted videos thank you
  13. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    For now I would suggest following the SMC3 instructions and tell us at what step anything goes wrong:
    8. Set Kp to about 400
    When SMC3 starts the pot should already be centered.
    What is happening in this part of the video, I can hear a clicking noise but have no idea what you are doing:
  14. titofe
    titofe Member
    642Coins
    hello tomorrow I attack your proposal I follow them. at 47 seconds it's me who moves the potentiometer the green line to align it with the blue.
  15. titofe
    titofe Member
    642Coins
    I just got the Sabah.2×32 card back. I can assure you that I plugged it in and it does the same thing as with the ibt2 cards
  16. noorbeast
    153,914Coins
    +11,156 / 57 / -2
    Here Max Limits is set to 0 and it does not look like the pot is centered, hence my suggestion to follow the SMC3 setup instructions to the letter, as a baseline:
  17. titofe
    titofe Member
    642Coins
  18. titofe
    titofe Member
    642Coins
    hello I just put some videos online to report that you asked me for the 10 steps to do thank you
  19. titofe
    titofe Member
    642Coins
  20. titofe
    titofe Member
    642Coins
