Question Attach the hall-effect 'potentiometer' on the motor shaft on Arduino SMC3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by prophet.id, Feb 6, 2025.
  1. prophet.id
    prophet.id BOSeTAMPER's Rotary Servo 6dof Build
    313Coins
    I am thinking to put the sensor on the motor shaft (Instead of on the gearhead shaft).
    Since I am using a 1:50 gear head and designing for a total maximum 90-degree motion angle of output/horn, my calculation for a Quarter rotation output of my motor would turn a total of 12.5 turns.
    So, I am thinking of getting 20 turn-hall effect potentiometers and attaching them to the motor shaft (it is a dual shaft motor, the front one attached to the gear head).
    My goal is to get the most precise output/horn without adding another gear up for the standard (single turn) potentiometer.
    Does this sound a good idea?
    Any suggestion which 20 turn-hall effect potentiometer I could try?
    153,734Coins
  3. prophet.id
    313Coins
    I suppose you missed my notes. I use a gearhead, and I am not planning to attach the sensor to the gearhead but to the motor shaft. This means the motor shaft will turn multiplier turns, 12.5x per my note.
    153,734Coins
    I guess I have to ask why, as the gearhead is where the culmination of the motor/lever position actually is, including any play, of which there will be some?
    Off a motor will work, but in my view adds unnecessary complexity unless there is a good reason for it.
  5. prophet.id
    313Coins
    It is just like a typical servo motor system to get the most precision as they have a rotary encoder on the motor shaft, not the gearhead output shaft.
    153,734Coins
  7. prophet.id
    313Coins
    I suppose, in terms of simplicity, attaching the 'potentiometer' to the gearhead's shaft (typically built) and to the motor's shaft should be the same.
  8. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,336Coins
    Question #1: can you write your own arduino code that will handle the multi-turn potentiometer ?
    If not then you can't use such a solution because SMC3 only supports single-turn potentiometers/hall sensors up to 270 deg. of measurement.
    Question No. 2: why are you concerned about the accuracy of the measurement , the backlash of the gearbox in any rotary slinky is much larger than the possible measurement error of the sensor attached to the axis of the gearbox.
  9. prophet.id
    313Coins
    #1 no need to rewrote the code. I just need a multi-turn "potentiometer" directly to the (rear) shaft of the motor.
    #2 I use a harmonic drive gearhead, which has a super small backlash. The issue I have now, the return position from multiple movements (either on Clockwise and Counter-Clockwise) was not precise enough. Perhaps off about 5 degree angles, when I have the "potentiometer" attached directly to the gearhead shaft (the horn). Tried on a regular 10K pot and 5V hall effect 360'.
  10. Attyla.pl
    Polska
    1,336Coins
    Ok, I have read the information about multi-turn potentiometers actually should work with standard arduino code.
    What are you building ? , so far no one was looking for that much precision measurement when building a motion sim.
  11. prophet.id
    313Coins
    I am building 6dof Steward with rotational actuators.
    "so far no one was looking for that much precision measurement when building a motion sim."
    Well, I guess you just found one is looking :D
  12. Attyla.pl
    Polska
    1,336Coins
    Ok, you made me curious :) what power of motors are you planning ?, how much such a motor with gearbox costs if it's not a secret ?
    Platform more for driving or flying ?
    In principle, a multi-turn potentiometer should work, provided you choose so that the movement of the lever is adequately reproduced by the number of turns of the potentiometer.
    Have you done tests with a Hall sensor ? such a
    https://www.ebay.co.uk/itm/P3022-V1...1YX&toolid=10001&customid=&ufes_redirect=true
    if so, what was the measurement error ?
  13. prophet.id
    313Coins
    Yeah... I tested that green boy as well. I also try the black housing from digikey (that usually higher quality source).
    I am currently planning to race, for now :D
    The harmonic gearbox is about $300-ish, landing in Boston (US).
    I use this DC motor, good enough efficiency https://amzn.to/3CJKuEX
    I documenting (photos and videos) here: https://www.instagram.com/stories/highlights/17943343157808731/
  14. Attyla.pl
    Polska
    1,336Coins
