2dof simulator
Discussion in 'Motor actuators and drivers' started by TomSim, Feb 12, 2025.
  1. TomSim
    TomSim Member
    192Coins
    Hi, I'm new here and just starting to build my first 2dof system. I have very strong industrial worm gear drive 1:51 and 160w 24v motor that also have 1:8 angle drive build in and out puts 480rpm. Motor it self puts out 4000rpm without worm gear. My question is should I take motors worm gear off and use that heavy duty industrial worm gear and get 78rpm out? If I would use them both as is I would get 9.5rpm and that do not work or am I wrong?
    My whole rig would be moving including wheel and pedals and maybe monitor that is 70" tv weights 20kg or 44 lbs
  2. TomSim
    TomSim Member
    192Coins
    I forgotten to say that I have 3 pcs those motors and worm gears and traction loss would be nice feature.
    152,700Coins
    +11,092 / 56 / -2
  4. Joe Cortexian
    1,369Coins
    The motor (according to the label) has 2 Nm or torque at 480 RPM. 20 Nm at 48 RPM is closer to what you need but still weak. 9.5 RPM is too slow to provide a satisfactory experience.
  5. TomSim
    TomSim Member
    192Coins
    I removed worm gear from the motor so now it puts out 4000rpm and if I now use that large worm gear that has 1:51 ratio, then rpm is 78. But how many newtons? I can buy new motors and that is no problem but I just would like to use those worm gears that I have because they are really heavy duty so they would last for a life time.
  6. TomSim
    TomSim Member
    192Coins
    I'm machinist so it's no problem to me to make all parts needed. Of course if 160w power jus is not enough then I just have to buy new motors.
  7. TomSim
    TomSim Member
    192Coins
    I think I'm gonna use MY1020 24v 500w with my 1:51 worm gears. Another option is MY1020 24V 350w if that would be better from the motor controller point of view. Can someone tell me what kind of controller would be sufficient in either case? It would also be interesting to know if there is anything bad about these motors for this use.
    I'm pretty sure the 70" TV isn't on the rack, just the bench, steering wheel, and pedals. I would be very grateful if someone could give me answers to these questions and I could get started on my project. My plan for the frame is to welded a tubular frame that is 40*40*1,5 mm steal square tube.
    Those motors are for electric bikes and sold in ebay, Alibaba and such places.
  8. Joe Cortexian
    1,369Coins
    I think that's in a range (maybe 15Nm) where it can move you around. If you are near the balance point it takes less than if it's at an angle. You can also reduce the torque requirement by using a shorter level arm. For example my rig works well with a 70 mm lever arm and sucks with an 80mm lever arm. I would go for it you will at least get some experience and maybe move onto a more powerful motor later.
    I measured my motors torque with a luggage scale. I had a 1oo pound scale and as I recall a 4 inch lever arm. I hooked the lever arm to the luggage scale with a rope and ramped up the PWM. In the end I came up with 36Nm. Maybe that 2Nm number on the motor is conservative and it's really twice that.
  9. TomSim
    TomSim Member
    192Coins
    I will measure torque and then decide what to do. I have force meter in my work place. Any opinions about those ebay's MY motors? Does anyone have any experience with them?
  10. Joe Cortexian
    1,369Coins
  11. TomSim
    TomSim Member
    192Coins
    I really would like to try these 500w motors if there is motor drivers that can handle 27,4A current. Torque would be 91Nm at 1:51 ratio! Maybe this is asking for troubles :D
    From what I looked at the power supplies don't cost much. 24V 30A 720W cost around 50$/each.
    Of course, it is not wise to oversize too much if the need for power is not going to be very great.
  12. Joe Cortexian
    1,369Coins
    Consider how you are going to attach a lever arm to this. They have to be rock solid.
  13. TomSim
    TomSim Member
    192Coins
    No. I would attach worm gear to the motor. These motors don't have gearbox. I would use axle couplers that I already have. You can see that worm gear in my first post.
  14. TomSim
    TomSim Member
    192Coins
    Can anyone please tell me what motor driver could handle this 500w motor? I'm about to make order 2 pcs these motors.
  15. TomSim
    TomSim Member
    192Coins
  16. Joe Cortexian
    1,369Coins
    That eBay controller should be fine. Wow, 60mm output shaft does give to a nice surface to attach your lever arm to.
  17. TomSim
    TomSim Member
    192Coins
    Actually it is 60mm aluminum shaft that's attached worm gears output shaft with keeway but it is so hard attached that I didn't get it loose so I'm making 3 pcs M10 threads in it to attach lever. That will hold:D
  18. TomSim
    TomSim Member
    192Coins
    What do you think about that 500w motor? There is 350w version too but I thought that 500w gives sharper movements and it has an extra reserve available if needed.
    Lord only knows how much peek current that 500w motor takes in actual use... depending rigs weight and balance but I think that 100A controller will manage it.
    On the other hand, the Chinese may tend to overestimate the power of their motors. I have an excavator bought from China with a nominal weight of 2000kg and a real weight of 1700kg. Sales tactics are their specialty, regardless of what they are selling.
  19. Joe Cortexian
    1,369Coins
    I would opt for the 500w. Then if you decide on a different configuration in the future it may still be viable motor.
    I have used the cheap ibt-2 controllers for three years and they drive the motors fine until they don’t. So for $42 you could buy 8 of those at Amazon but to be fair they are single channel.
    Recently I bought the single channel version of the eBay one and it melted the power supply or coincidentally my power supply melted shortly after plugging this in. Worked for awhile but is suspect because it seemed to not recover after I removed 24v power. The ibt2 I remove 24v often and sometimes if there is a problem removing the 24v fixes it.
    My lever arm is secured with two M6 bolts but it’s all steel. I don’t know how the aluminum will fair but 60mm should drive a backhoe.
    I bought a slide hammer to remove the key ways from my shaft. Now I don’t worry so much about pounding on them.
  20. TomSim
    TomSim Member
    192Coins
    Little by little, progress is being made. M10 threads done and the frame sketched. Should start welding the frame this weekend. The draft of the body is partly valid but some points will change.
    The pipes used are mainly 20mm*40mm steel with 1,5mm wall thickness. Under the bench will be 2 pieces of 40mm*40mm* with 2,0mm wall thickness. Support structures will be 20mm*20mm with 1,5mm wall thickness. Interesting to see how lightweight it will be.
