SimTools v2 - Video Ride Creator v2.1
Create video ride films for the Video Ride Player
  1. Titobial
    Titobial Member
    Zaragoza
    107Coins
    Escribe en inglés y me dices que no lo hago así. Soy española y traduzco todos mis mensajes al inglés, pero no sé por qué no me aparece en inglés!!! Quizás sea porque en la misma página tengo la opción de tenerlo todo traducido del inglés al español y por eso te lo envío en español. ¡¡Estoy harta!!
    I write in English and you are telling me that I don't do it that way. I am Spanish and I translate all my messages into English, but I don't know why it doesn't appear in English!!! Maybe it's because on the same page I have the option to have everything translated from English to Spanish and for this reason, I send it to you in Spanish. I'm fed up!!
    153,914Coins
    +11,156 / 57 / -2
    The above quoted post is not English, we appreciate your frustration but the issue is with your own posts and the Forum Rules are clear, all posts must be in English: https://www.xsimulator.net/community/threads/forum-rules.9527/
    Keep in mind it is also an admin task to manually translate for you to clean up your non-English posts, and while every effort is made to alert members such as yourself to that, there are also limits as to how many times non-English posts will be flagged and edited for compliance with the Forum Rules, before deletion is the only viable option.
    You do need to resolve whatever the issue is at your end that results in non-English posts.
  3. Neil Sultana
    Neil Sultana ns12
    2Coins
    Hi guys,
    I have built a 2DOF motion platform and wish to combine 360 footage for VR with telemetry using Video Ride Creator. It seems that this is possible however was wondering if there is some form of tutorial or information on how to get started with setting things up, thanks a lot!
  4. peter stolmeier
    peter stolmeier Member
    558Coins
    I'm not an expert but i have been playing with it a lot lately. Let me share what I know for 2D, and maybe it will help you work out 360.
    First thing is to install the ride recorder and just do some simple stuff on your fav game. This gives you reliable telemetry for your personal rig for testing.
    Then install the ride player plugin in simtools 3. double clicking on that will open a video player that you can then select the video and telem data you just created. Some of the details about settings will start to become clear and you'll build a foundation for learning what you need to learn.
    After that it's about figuring out how to play 360 video. (I'd post convert to 180 btw) The player it comes with might handle it by default, I'm unsure.
    If you find yourself stuck at the capture process, we'll need ask the actual experts to help set that up because I still don't understand how to output the telem in a way the recorder will understand reliably. You might find it works easy for you off the bat though.
  5. Neil Sultana
    Neil Sultana ns12
    2Coins
    Hi Peter,
    Great stuff, will do a test this evening. Thanks a lot!
  6. Menix
    Menix Member Gold Contributor
    104Coins
    Anybody know were to download those vido rides like in Disneyland?
