Arduino+sebartooth 2×32
Discussion in 'DIY Motion Simulator Projects' started by titofe, Feb 17, 2025.
  1. titofe
    titofe Member
    640Coins
    2DOF, Arduino, SimforceGT, Motion platform
    hello thank you for your answer it is exactly this one.
    151,467Coins
    +11,041 / 56 / -2
    Can you please post a picture of your SMC3 setting running the Sine test.
  3. titofe
    titofe Member
    640Coins
    hello thank you for your help here are the photos I put two more photos to see the value output of the motors, the values which are displayed in SMC 3 they were put automatically when I turned on the application, smc3 thank you for your help.
  4. titofe
    titofe Member
    640Coins
    151,467Coins
    +11,041 / 56 / -2
    Can you please verify the comm port has not changed in Device Manager.
    Given you had this working have you done anything that may have damaged the hardware?
  6. titofe
    titofe Member
    640Coins
    the gate is good. I noticed something in the dips 1 2 3 4 5 6.1 and 2 off the other numbers in ON there is no value coming out but when I put all the dips in ON the motors start to turn. Thank you.
  7. titofe
    titofe Member
    640Coins
  8. titofe
    titofe Member
    640Coins
  9. titofe
    titofe Member
    640Coins
    hello friends and thanks to prophet.id his answer was useful. after changing all that here is a video, why he is shaking like that thank you, friends
  10. titofe
    titofe Member
    640Coins
  11. titofe
    titofe Member
    640Coins
    Hello friends, I managed to recover some of the settings but they are still strange. Does anyone have any ideas? Thanks for your help.
  12. titofe
    titofe Member
    640Coins
  13. titofe
    titofe Member
    640Coins
    151,467Coins
    +11,041 / 56 / -2
    Try setting PWMmax and PWMrev to 150 and then run the Sine test.
  15. titofe
    titofe Member
    640Coins
    Thank you for your fairly fast answer, thank you very much, I will keep you posted from the future.
  16. titofe
    titofe Member
    640Coins
    Hello, thank you for the answer, but it's even worse if I go up to 150. I'm going to take the engine apart, I find that there's a lot of play inside. I'll keep you posted on the rest, thank you☺️
    151,467Coins
    +11,041 / 56 / -2
    Following the SMC3 setup instruction at what PWMmax value does the motors start to move:
    8. Set Kp to about 400
  18. titofe
    titofe Member
    640Coins
  19. titofe
    titofe Member
    640Coins
    I managed to move the two engines I am settled with Simtools and the LFS I will keep you posted afterwards thank you very much.☺️☺️
  20. titofe
    titofe Member
    640Coins
    Hello friends, I'm posting two videos with the settings. I've finally reached the end of the project. Thank you all for your help. It's great to continue with you. Thank you.
