Question Do I Need Mechanical Stops?
Discussion in 'DIY peripherals' started by esloch, Feb 25, 2025.
  1. esloch
    esloch New Member
    34Coins
    I'm still working on my FFB wheel ... a simple G92-style wheel ...
    I have a technical question—I hope it’s not too silly .. : The wheel will later work in 900° mode (normal mode) and 300° mode (F1 mode). (Are these angles correct?) .. I need to know if I need mechanical stops and how to place these mechanical stops ... Or is this managed entirely by the simulation software?
    Thanks!
  2. elnino
    elnino Active Member
    Computer Geek
    Adelaide, Australia
    1,557Coins
    No, you don't need mechanical stops. The firmware basically creates a hard stop using the motor. You can push past it if you force it, but when you're driving it will feel plenty hard
