SimTools v2 - Video Ride Player v2.2
Play video ride films reformatted or created by the Video Ride Creator.
  1. peter stolmeier
    peter stolmeier Member
    528Coins
    I've got the plugin installed for simtools 3 and the player is showing telemetry when the video plays. The system auto activates when the player is running so it sees that, but it doesn't show any of the values in simtools.
    I must be missing a step somewhere. I prefer to look up issues before I ask but I can't find anything about it.
  2. yobuddy
    50,992Coins
  3. peter stolmeier
    528Coins
    For the plugin I'm using v3 for sure, but the player for 2. There's not one for 3 right?
    Assuming I'm using the most updated versions for both it sounds like it should be working. Perhaps I should uninstall and reinstall.
    151,991Coins
    +11,061 / 56 / -2
    @yobuddy linked the v3 player: https://simtools.us/plugin/?varname=1526&color=0e97dd
    SimTools v2 plugins are not compatible with v3.
  5. peter stolmeier
    528Coins
    That is the plugin, not the player. I have the v3 plugin and v3 simtools. If I understand correctly that plugin listens for the player to start a video, correct?
    The question: Is the player called "SimTools v2 - Video Ride Player" or is there a V3?
    I'm pretty sure v2 is correct, I think I found my missing detail.
    I made the .cfg file match the video name, I did not add the frame rate and type. I can't test it till tonight, but I'm not sure that's it because the player runs the numbers, it just doesn't appear to send them to simtools.
  6. yobuddy
    50,992Coins
    This is actually the plugin, and the player for SimTools v3.
    (Double clicking the play button launches the SimTools v3 player)
  7. peter stolmeier
    528Coins
    aaah ok. I thought I was missing something like that. Now I'm REALLY excited to boot up the sim tonight!
    Thanks!
  8. peter stolmeier
    528Coins
    Update: it worked!
    My telemetry is so bad it's dangerous but I can redo it now that the player is playin'!
