2 dof help
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by kai, Mar 27, 2025.
  1. kai
    kai New Member
    124Coins
    looking for someone that can walk me through setting up my first 2 dof rig my potentiometers im using 10 k are being weird and just general setup with software and assetto corsa so yead it would be good if you could drop your discord or somthing so when im setting it up i can call
    cheers
    153,920Coins
    +11,156 / 57 / -2
    What hardware and code are your using?
  3. kai
    kai New Member
    124Coins
    im using all of the normal parts that dmax used exept for different motors and potentiometers mine are 10 k and the moters are wheelchair motors
    153,920Coins
    +11,156 / 57 / -2
    Thanks, can you please post details of the control hardware and code, along with pictures of all settings.
    I am guessing that may be Arduino, IBT2s, and SMC3 but that does need to be clear.
  5. Joe Cortexian
    1,549Coins
    At the end of those videos he kinda says the motors don’t have enough power. Can you post a picture of the label? It should at lease have a wattage on there that is related to the power. Also, the RPM since higher RPM implies lower torque.
    It is also possible to measure the torque with a luggage scale of a fish scale.
  6. kai
    kai New Member
    124Coins
    yes ibt2 arduino uno 24v power supply and 10k potentiometer
  7. kai
    kai New Member
    124Coins
  8. Joe Cortexian
    1,549Coins
    I think this may be ok. Typical wheel chair motors are in range. In my mind I thought you said windshield wiper motors which is a concern.
    I have seen some I this form factor that are 320w which would be great.
  9. kai
    kai New Member
    124Coins
    could you guys give me your discords because the program setup is what i need help most with cheers
