FlyPT Mover 3.7.0.17
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,838Coins
    DC motor, 6DOF
    I have an error while connecting my board. In the last release I tried. @pmvcda plrsse assist.
  2. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Ok, it works with a dedicated Thanos interface. Thanks
  3. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    WHO knows what « Head is in the compensation module ?
  4. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    @pmvcda I have difficultés to save the output Joystick Mapping in the options. Although visible in the settings they stop working fter restart. Start minimized doesn’t save as well.
  5. Marco Annunziata
    919Coins
    Is there anyone using Mudrunner with Mover?
  6. pmvcda
    15,702Coins
    I had some pointers for that, need to look for it. But they where always updating it and the pointers changed.
    I can take a look again
  7. pmvcda
    15,702Coins
    @hexpod
    Sorry for the delay.
    I'm working on a new release to solve a bunch of bugs present in the current beta
    Need some more days
  8. Marco Annunziata
    919Coins
    Thanks a lot, take a look to Expeditions (a Mudrunner game) should be the last version
  9. pmvcda
    15,702Coins
    I think they don't have telemetry. I will have to use hooks injectors...
    It's usually a big problem with game updates. I will take a look. Sometimes it's possible to do something to capture values even with updates.
    I have done it for snowrunner, but with the updates at that time, it was a problem.
  10. Genociple
    Genociple New Member
    62Coins
    Hello im in v3.7.0.9 and the 6dof cable sim has some weird singularity issues, on the xy plane it seems that it cant extend to the limit of the cables which i assume has some sort of bounds related to tension but should still be possible I think. whereas max height would cause infinite tension in the top cables. But the main issue i have is i can't go as low as I can high. screenshots for example:
    also can i make it so it has a 6 cable setup rather than 8?
  11. Chad Hamilton
    Chad Hamilton New Member Gold Contributor
    - 4Coins
    Hey I have been trying to get my odrives to work with the new firware but they a moving from the min to max when they should be staying still.
  12. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi!
    If mover doesnt send commands (what is difficult to see in the short scene) and your rig is still moving, then I think the reason could be the motor tuning settings. For example: if the position gain is too low, the motor will not be able to reach the exact position. But sometimes the motor tries to chase the position.
    I saw this also on my rig in the past, but only with tiny movements...
    So this is only an idea
  13. Chad Hamilton
    - 4Coins
    Yep you where right my config file was corrupted.
  14. Marco Annunziata
    919Coins
    Does the MAXACCEL function work for anyone?
    For example, could someone please tell me what gets with this operation MAXACCEL(VALUE;50;0)?
  15. SilentChill
    20,601Coins
    Finally got chance to try again and using bit values works great :) I will try and see if I can get everything else up and running now
    thanks @pmvcda
  16. SilentChill
    20,601Coins
    I have no idea how to set my Wind fans or my Belt Tensioners up as the simple direct has no options like in the old Mover ? There is no actuator key to input the Wind Or LeftBelt RightBelt key
    Old
    New
  17. Erik Green
    Erik Green Member
    409Coins
    Struggling with directs myself. set up 4 directs to drive a g-seat like Chris Fischer's design. Cannot get them to show data at the M4S output. They show as: <D0.A.B> <D1.A.B>
  18. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
    Wouldn't it be a good idea to export small corrections on a more regular basis for follow-up? There aren't many left.
  19. hexpod
    berlin
    7,838Coins
    DC motor, 6DOF
  20. Flymen
    Montreal, Canada
    2,470Coins
    DC motor, 6DOF
    107267
    Hi Pedro !
    Unfortunately, I had no success to connect the two ESP32 controllers with the serial outputs (speed 115200 or 921600 like the old version) every time I want to connect, I have a blue screen and the pc shutoff .
    With the MMF output it works but Port 3 or 4 does not seem to communicate, in the rig the bits is at 15 and when I return to the old version everything works wonderfully .
    Have a good day !
    Thanks ! @pmvcda
    Eric
