Bug No comunication between PC and Seatmover
Discussion in 'SimTools DIY Version' started by Andre72, Apr 4, 2025.
  1. Andre72
    Andre72 New Member
    40Coins
    Seatmover with track los
    1. not built by myself but DIY
    2. DOF 3
    3. accuators are from wheelchairs, works like windshield wipers
    4. Interface SIMATIC S7-300, CPU 314C-2PN/DP
    SimTools
    1. Version Number: 3
    2. Game Plugin where the error is happening: I have no comunication between the PC and the Simatic
    3. Settings (Relevant settings) I habe screenshots from the old seetings (Vers.2.1).
    Hello everbody,
    my name is Andre, I´m 52 and my english is a little rusty - sorry therefor. My problem is, I bought a used seatmover, but the PC brokedown and I had to install it new. But no there is no comunication between the PC and the Simatic. I used screenshots from the old PC for the right IP, but it doesn´t work. The PC teels only unknown network. I chanced the IP in the network to the IP it used to be - but nothing works. Do I need special software from siemens to make it working, or do you habe any ideas, what went wrong. If you need farther informations, please tell me.
  2. yobuddy
    50,744Coins
    Please post the picture of your old settings buddy. My guess is the ip addresses have changed in your network, and you will need to figure out what IP address your controller is actually using.
    Chat soon!
  3. Andre72
    Andre72 New Member
    40Coins
    Hi yobuddy,
    now I know a little bit more. I changed the IP of the ethernetcard and now I´m able to ping to my 314-C. Here is the screenshot from the owner before me. How can I figure it out, where the problem is?
  4. Andre72
    Andre72 New Member
    40Coins
    One thing I forgot to tell: I first installt Simtool 2.1 and now I´m not able to delit it and when I start windows there comes an information. I send it below.
  5. yobuddy
    50,744Coins
    Sorry buddy, but the pic of your settings is to small not readable.
    But my guess is your interface has a different ip address, and or port, that the one you are supplying.
  6. Andre72
    Andre72 New Member
    40Coins
    I didn´t knew, that the pictures can´t be zoomed, hier another try. This IP is the IP I can ping. I have 2 interface cards and deaktivated the one for the internet. So the problem with the wrong interface should be solved, or have I missunderstood you? As I completly reinstalled my windows, the problem with 2 different softwareversions is solved. What else can I check?
  7. yobuddy
    50,744Coins
    Please try <Axis1a><Axis2a><Axis3a><Axis4a><Axis5a><Axis6a> for interface output.
  8. Andre72
    Andre72 New Member
    40Coins
    Thanks a lot yobuddy - the problem is solved. As I didn´t refresh the page, I just saw it now.
    Greats Andre
