Question I'm having trouble looking for aluminum extrusions and motors for SFX–100 sim in the US
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Radioactive_pickle1, Mar 4, 2025.
  1. Radioactive_pickle1
    Radioactive_pickle1 New Member
    52Coins
    Hi, I’m looking for help with the Sim feedback SFX–100 I'm having trouble looking for a good supplier for the aluminum extrusion and motors. because I’m having trouble finding suitable parts in the US.
  2. Joe Cortexian
    1,333Coins
    No answers. Only Ali Express. I did find another company that sold kits but I think they are most likely in China.
    Note that there are much less expensive alternatives for AC servos now. Check out this thread:
    https://www.xsimulator.net/community/threads/aasd15-alternative-thanos.18984/
    Most of the linear actuators are associated with 6dof but they could all work for a SFX system as well. I decided to make my own design but it’s just in my head for now.
    I have seen SFX-150 stuff also. You might try a search for that.
  3. Radioactive_pickle1
    52Coins
    got it, thank you
  4. silver66fb
    silver66fb New Member
    24Coins
    I bought my extrusions on Alibaba. Had to modify the printed sliders a bit, but they fit fine now. The motor/actuator sets I am purchasing are RATTMOTOR on Amazon (750W, no brake). $149/set.
  5. Radioactive_pickle1
    52Coins
    Yeah, I ended up buying my aluminum from the item 24 website and I had to shave my sliders a little bit too. but I found for my motors a 110v version on Alibaba, which I decided to buy instead of the ones suggested on Amazon.
  6. silver66fb
    24Coins
    No need to purchase a 110V version. Just change the motor controllers' low voltage alarm to 100V and run them on 120V. They run at half speed, but that's ok. No need to run 240V circuits or purchase a transformer, like some have done.
  7. Misanthrop
    Misanthrop Active Member
    724Coins
    The ST80 Motors will have a max speed of 2300rpm, instead of 3000rpm.
    Don´t know where the rumor come from with only half the speed.
  8. silver66fb
    24Coins
    I'm not sure I understand what you mean. What is the rumor about half speed?
  9. Misanthrop
    724Coins
    2300rpm instead of 3000rpm is not half of speed.
