Beamng with BeamNgpy server is not working with Simtools plugin
Discussion in 'Other Racing Games' started by Badrick, Apr 10, 2025.
  1. Badrick
    Badrick New Member
    35Coins
    Dear Developer community!
    First of all thank you for your effort with these plugins.
    The latest plugin is working without an issue with my BeamNG if I start with the Launcher, but I started a project myself which is required a BeamNGpy to control the main sw from outside.
    For this the Python coltroller start the game with this command line:
    BeamNG.drive.x64.exe -nosteam -console -tcom-listen-ip 127.0.0.1 -lua extensions.load('tech/techCore');tech_techCore.openServer(64256) -userpath C:\Users\bosch\AppData\Local\BeamNG.drive
    I'm starting the Beam like suggested in the official document:
    beamng = BeamNGpy("localhost", 64256, home="\BeamNG.drive.v0.34\game")
    beamng.open()
    And if I would like to use my SimTools I've got this error message:
    System.ComponentModel.Win32Exception (0x80004005): A 32 bit processes cannot access modules of a 64 bit process.
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    It is the same issue appear if I just doubleclick to BeamNG.drive.x64.exe in Bin folder. But everything is working as expected with the Launcher.
    It would be really any case of help :)
    Thank you!
    153,890Coins
    +11,154 / 57 / -2
    @yobuddy can likely advise, when he has a spare moment.
  3. Badrick
    Badrick New Member
    35Coins
    Thank you! :) Looking forward to it.
  4. yobuddy
    51,535Coins
    Hi @Badrick,
    BeamNG sends its data over UDP. It's like Live for Speed where it actually sends its motion data to 4123 and its dash data to 4124 (How its setup in v3 plugin anyway) It looks like your starting the game up with a different port is all - 64256. Now this should not cause the error you show above (simply missing data as its going somewhere else)
    I'm not sure what is trying to connect to the games 64bit module, as the game simply sends data over udp and the output is caught by the game plugin. There is no direct access of the games modules here.
    Looks like your using SimTools v2, I suggest you give SimTools v3 a shot. As I don't have the source code for the BeamNG v2 plugin, so I can't say for sure how its currently working. But I see no reason you should get these problems with the v3 build of the plugin.
    To be honest, I'm not sure what exactly your doing with python here. But it may be worth seeing if python is running in 32bit or 64bit mode. As it sounds like its directly interacting with the game. If your using the 32bit version, it could cause this error. (A 32 bit processes cannot access modules of a 64 bit process.)
    Please let me know how it goes,
  5. Badrick
    Badrick New Member
    35Coins
    Hello @yobuddy !
    First of all thanks for you answer!
    I building some ADAS test environment in BeamNG. That's why I'm using BeamNGpy API to control the game. This is an experiment from myself just for fun.
    However I do not need to start the game with the python module to get this 32 bit / 64 bit error. If I start the game simple with BeamNG.drive.x64.exe from the BIN64 folder I got the same error massage. It is related somehow to servers starts, just couldn't figure out why.
    If I use the game launcher everything is working as expected.
    Maybe a useful info, I do not use the V3 version yet.
  6. Badrick
    Badrick New Member
    35Coins
    Sorry I've been really busy in the last few months! But huge thank you, V3 get the job done for motion. I was able to setup! :)
    Next step for me are the bassshakers. It is out of the topic, but I hope this question can stay.
    With the "Test settings" I've output and the shakers are doing their job. But the game is not controlling it.
    In High/Low tuning there are valuas which are uploaded accordingly.
    Some screenshots:
    https://imgur.com/a/xKORQxu
    Thank you in advance!
  7. Badrick
    Badrick New Member
    35Coins
