Sort of DIY
Discussion in 'Commercial Simulators and Peripherie' started by Doon1, Feb 15, 2025.
  1. Doon1
    Doon1 Member
    391Coins
    I bought a used (broken) DOF reality P3 cheap. As I only fly helicopters and small GA planes in MSFS, I found the backlash and cogging to be very jarring and totally immersion breaking. DR's putting together a kit like I'm building, but it will be some time before it's available for my model and the cost will be pretty high compared to what I paid for the machine. So I decided to mod it myself. I've mentioned this rig in a couple other thread but thought I should move it here and document the procedure. I want to start with a question though.
    I purchased the 5:1 planetary gearboxes prior to doing the math. I even cut one to fit the motor. Was a serious learning curve regarding precision aluminum machining, but I now have the proper measuring tools and knowledge to do it; so i can't begrudge the $65 I spent on the box if it proves to be useless for my needs.
    I can send the other gearbox back and get 3:1 boxes if the 5:1 stop-to-stop time is not acceptable. NOTE: I'm older with a not-so-great back, so I don't want to be slung all over the place.
    I'm using the original motors and mounting point on the rig that DOF Reality used so I know the geometry works.
    Here's my math.
    Motor speed = 3000 RPM = 50 RPS
    1605 ball screw = 5mm per/rotation
    Total length of ballscrew travel = 70mm
    5:1 GEARBOX: 50 RPS / 5 = 10 RPS = 1.4 seconds stop-to-stop.
    3:1 GEARBOX: 50 RPS / 3 = 16.67 RPS = 0.839 seconds stop-to-stop.
    Total distance of actuator arm travel = 92mm. This is 90 degrees of total rotation, using the existing DR actuator arm, with the seat link located in the last hole.
    What do you guys think? Keep the 5:1 gearboxes so I only have to cut one more, or get the 3:1 gearboxes?
    Gearbox input housing removed,
    Mounted,
    cut,
    Finished,
    Fitted,
  2. Doon1
    Doon1 Member
    391Coins
    It's alive(ish)...
    153,884Coins
    +11,154 / 57 / -2
    Curiosity question, what purpose does the blue cord serve, and should it really rub on the screw?
    As an aside, it looks like there is still some refinement to come for SMC3 settings.
  4. Doon1
    Doon1 Member
    391Coins
    Hello Noorbeast.
    The unit isn't bolted down yet. Hence the bungee cord. I was just testing for clearance before I drill the holes in the the base and mount. I'm going out of town this weekend so I won't get to play with it, but I couldn't wait to see if it would move. Your right about the settings. There's a FB group dedicated to modding the DR machines. I have a request in for SMC3 and SRS settings from folks that have the manufacturer's SFU/planetary motors. I still have to put it through it's paces before I commit to making the second one. Cogging and backlash look pretty much nil even with the standard settings, but the speed needs to be increased. Still haven't ruled out the 3:1 planetary in place of the 5:1 that's on it. I hope to have it bolted in place and put some weight on it next week.
  5. Doon1
    Doon1 Member
    391Coins
    I swapped overt to the Phidget motor/planetary unit for more speed. I was concerned that the motors would be too weak but they are not. I still have to install the new cables and connectors as well as hook the original traction loss motor back up. It works very well in MSFS. No backlash or cogging at all (that I can feel anyways). I'm going to spend today trying to figure out Simhub, as I need it for the Razer haptic pad. First I'm going to fly around Manhattan for a couple hours though.
  6. Radioproffi
    Lviv
    1,677Coins
    easy way to increase speed - use 1610 ball screw nut
  7. Doon1
    Doon1 Member
    391Coins
    Been busy with life for the past few months. I just installed 1610's. Was ready to fire up MSFS and my internet went down. They are much faster and still strong enough to throw me around. I'll make a vid once my internet comes back up.
  8. Doon1
    Doon1 Member
    391Coins
    The 1610 and Phidget motor combo is not good. More cogging during slow, small movements than the manufacturer's original setup.
    To summarize:
    Original P3 worm-gear motor = good torque, good speed, noticeable cogging. terrible backlash.
    Original motor + 5:1 planetary gearbox + 1605 ball-screw = good torque, poor speed, no cogging, no backlash.
    Phidget motor + 1605 ball-screw = good torque, med speed, no cogging, no backlash.
    Phidget motor + 1610 ball-screw = low torque, good speed, very noticeable cogging. no backlash.
    I’m going to try the original motor and 5:1 planetary again, but this time with the 1610 ball-screw. This will match the gear ratio of the Phidget/1605 combo, but with greater torque and power. I believe the Phidget motor lacks the initial torque and raw power of the original motor, which contributes to the low-speed cogging. I’ve also gained a much deeper understanding of the SMC3 settings than before, and I’m hopeful that with improved settings and the stronger motor, I’ll be able to find the sweet spot.
    I’ll keep you all posted.
