Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. noorbeast
    152,553Coins
    +11,087 / 56 / -2
  2. Kevinski
    Kevinski If it doesn't fit, hit it until it does.
    Australia
    381Coins
    Love the lime green George. Great work on cleaning up your files. Will try and have a tutorial up by Sunday.
  3. Alvaro George Menendez
    Alvaro George Menendez New Member Gold Contributor
    Sydney NSW Australia
    69Coins
    Thanks for the tip Noorbeast. I have tried it in various positions before welding it in place as it lends itself to the best-balanced point with me in the seat. I followed Kevinski's design & advise to have a moveable seat frame (in green with springs to accentuate surge/heave) that I can push forward in the top frame if we find the motors struggle a bit. The genius in this design is that we can slide the green frame (with the seat) forward along the black top frame easily hence closer to the uni joint. Thanks again for the input...
  4. Alvaro George Menendez
    69Coins
    Thanks mate.. It's a father / daughter ADHD project... the green matches her nail poilish .. Hahahahahaha !
  5. Kevinski
    Australia
    381Coins
    @Alvaro George Menendez Better late than never George. Hope this helps with your issues.
  6. Alvaro George Menendez
    69Coins
    Thanks Kevin - appreciate your time and effort to help me through it.. will watch it now and follow the instructions. On another matter... I've been playing around with getting a seatbelt tensioner to work on the motion sim rig. See the photos of my crazy handiwork so far as i only started on it this afternoon ... trying to use the differential changes in latitude between the top frame and the central spine to give me left and right pulling force on the seat belt straps so that it translates into G force sensation. The winch rollers may be required to mitigate losses between vertical and horizontal plane change of the shoulder straps at the top of the seat. The green (with the big Knot ) and Blue rubber straps that connect the bottom of the rig to the seat belt straps are required to get that left and right "pulling" force sensation.  Thanks again Kevin! tensioner IMG_8775.jpg tensioner IMG_8776.jpg tensioner IMG_8777.jpg tensioner winch roller IMG_8778.jpg
  7. Alvaro George Menendez
    69Coins
    Hi Kevin ... It's ALIVE It's ALIVE ! Followed your video as soon as I got home from a field trip this week.. worked first go, but it did surprise me as I didn't have the right values in SMC3 set.. LOL bent a 10mm threaded tie rod a little.. It's a beast of a rig and deserves respect. Again mate - Thank you for your valuable time and effort in helping me out. I also got the chance to finish the seatbelt tensioner.. all for under Aud $100 ( pre loved 4 point harness and 2 x boat trailer rollers ) first trial smc3 settings IMG_8786.jpg first trial smc3  ooops IMG_8784.jpg
  8. Kevinski
    Australia
    381Coins
    I reckon we should discuss this stuff in a separate thread George so we aren’t polluting this thread with unrelated sabretooth specific stuff. I’ll message you and we’ll go from there.
  9. Tricsixty
    Tricsixty New Member
    LAME
    Adelaide, South Australia.
    7Coins
    4DOF
    I am about to lose my s%$#, I can't get the script to upload despite following the step by step. I have two 2 x 60 ST with Uno R4s. I get the following when I try and verify -
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:145:17: error: 'PORTD' was not declared in this scope
    int OutputPort =PORTD; // read the current port D bit mask
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void setPwmFrequency(int, int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:256:13: error: 'TCCR0B' was not declared in this scope
    TCCR0B = TCCR0B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:260:13: error: 'TCCR1B' was not declared in this scope
    TCCR1B = TCCR1B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:278:13: error: 'TCCR2B' was not declared in this scope
    TCCR2B = TCCR2B & 0b11111000 | mode;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void InitialisePWMTimer1(unsigned int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:286:3: error: 'TCCR1A' was not declared in this scope
    TCCR1A = (TCCR1A & B11111100) | (wgm & B00000011);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:287:3: error: 'TCCR1B' was not declared in this scope
    TCCR1B = (TCCR1B & B11100111) | ((wgm & B00001100) << 1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:299:3: error: 'ICR1' was not declared in this scope
    ICR1 = CountTOP; // Set the TOP of the count for the PWM
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void InitialisePWMTimer2(unsigned int)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:315:5: error: 'TCCR2B' was not declared in this scope
    TCCR2B = TCCR2B & 0b11111000 | Timer2DivideMode;
    In file included from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/String.h:33:0,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/IPAddress.h:24,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/ArduinoAPI.h:30,
    from C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/Arduino.h:4,
    from C:\Users\user\AppData\Local\arduino\sketches\3C58A3BA5EA2888EFC33DE08A0B2F8D6\sketch\SPS_8.2_softstart.ino.cpp:1:
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void MyPWMWrite(uint8_t, uint8_t)':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:21: error: 'TCCR1A' was not declared in this scope
    sbi(TCCR1A, COM1A1);
    C:\Users\user\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.4.1\cores\arduino/api/deprecated-avr-comp/avr/pgmspace.h:38:23: note: in definition of macro '_SFR_BYTE'
    #define _SFR_BYTE(n) (n)
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:17: note: in expansion of macro 'sbi'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:29: error: 'COM1A1' was not declared in this scope
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:50: note: in definition of macro 'sbi'
    #define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:342:29: note: suggested alternative: 'COM1'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:46: error: '_BV' was not declared in this scope
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:78:46: note: suggested alternative: '_B'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:344:23: error: 'ICR1' was not declared in this scope
    top = ICR1; //Timer1_GetTop();
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:347:29: error: 'COM1B1' was not declared in this scope
    sbi(TCCR1A, COM1B1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:347:29: note: suggested alternative: 'COM1'
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:353:9: error: '_SFR_MEM16' was not declared in this scope
    _SFR_MEM16(regLoc16) = tmp; //(tmp*top)/255;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:353:9: note: suggested alternative: '__REV16'
    __REV16
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino: In function 'void setup()':
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:393:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:399:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:406:14: error: 'class SoftwareSerial' has no member named 'end'; did you mean 'read'?
    mySerial.end();
    read
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:419:16: error: 'PORTD' was not declared in this scope
    OutputPort=PORTD;
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:9: error: 'ADCSRA' was not declared in this scope
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:5: note: in expansion of macro 'sbi'
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:9: note: suggested alternative: 'ADC_0'
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:452:16: error: 'ADPS2' was not declared in this scope
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    sbi(ADCSRA,ADPS2);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:453:16: error: 'ADPS1' was not declared in this scope
    cbi(ADCSRA,ADPS1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:75:51: note: in definition of macro 'cbi'
    #define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:453:16: note: suggested alternative: 'ADC_1'
    cbi(ADCSRA,ADPS1);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:454:16: error: 'ADPS0' was not declared in this scope
    cbi(ADCSRA,ADPS0);
    C:\Users\user\AppData\Local\Temp\2533a47e-c1b0-45dc-a476-93c0161f77a3_SPS_8.2_softstart(2).zip.7a3\SPS_8.2_softstart\SPS_8.2_softstart.ino:454:16: note: suggested alternative: 'ADC_0'
    cbi(ADCSRA,ADPS0);
    Multiple libraries were found for "Sabertooth.h"
    Used: C:\Users\user\Documents\Arduino\libraries\Sabertooth
    Not used: C:\Users\user\Documents\Arduino\libraries\8127a25499541b9f64b53ae8c9261ffb-0ef79203ed4b02940acc17d47e0953b
    exit status 1
    Compilation error: 'PORTD' was not declared in this scope
  10. Tricsixty
    LAME
    7Coins
    4DOF
    Disregard my post. I was using a new R4 Arduino which is not compatible with the script.
