Question Can I change motor direction in FlyPT for one Linear Actuator?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Tim Herschbach, Apr 26, 2025.
  1. Tim Herschbach
    Tim Herschbach Member Gold Contributor
    585Coins
    I've constructed rack & pinion drives from the ali wheel chair motors but because they behave like actuators (not a rotating crank), I'm setting up the rig in FlyPT as a 2DOF linear actuator rig. However, because the motors are mounted mirrored, one is reversed. I already swapped the power to the motor but realized I need to change the polarity of the hall sensor too, so before I mess with that, is there an easier way to do this within FlyPT? Seems like there should be a way to reverse a linear actuator's direction like you can reverse the motor's direction when setting up the 2DOF rotating rig.
  2. Tim Herschbach
    585Coins
    Or is there a simple way to do this in the ard sketch?
    EDIT: I'm not even sure how to reverse the output of the hall sensor... from what I'm seeing you can't switch polarities. So I'd either have to mount it facing the other way, or do it in software it seems? Or get crazy and just put a twist in the o-ring. :D
  3. Attyla.pl
    Attyla.pl Active Member
    Polska
    1,332Coins
    See, I think in arduino smc3.ino you can reverse the movement of the motor.
    Possibly in flyptmover swap direction
  4. Tim Herschbach
    585Coins
    That's a rotating DoF. I need it for a linear.
    I suspect it's easily done in SMC3 but my coding ability isn't great so if anyone knows how to do it off hand, please let me know.
    In the meantime, I put a twist in the o-ring and it's working perfectly!
  5. Attyla.pl
    Polska
    1,332Coins
    Just edit the draft smc3.ino in line 13 and delete the // characters
    Motor 1 will move in the opposite direction of the instructions sent from the program.
    Note, I have not tested this function personally reverse Motor 1 direction.png
  6. Tim Herschbach
    585Coins
    Easier than I expected, thank you! The o-ring twist is putting a small amount of friction on itself so not the ideal solution.
  7. Tim Herschbach
    585Coins
    Finally got around to trying this, but I'm using Sebastian's I & D fix + slow start version and it's not there. I wonder if I could just add the line? Doubt it.
  8. Attyla.pl
    Polska
    1,332Coins
    Unfortunately this is not enough, maybe Sebastian could add the code from the original smc3.ino ?
