Phidget motor 4001
Discussion in 'Motor actuators and drivers' started by Deleted member 51784, Apr 27, 2025.
  1. Deleted member 51784
    It seems that several people are using these PMDC motors to run a ballscrew type actuator (DOF Reality H3 and H6). Looking at the specs it says it's a 100 watt output motor. $80 for a motor/gearbox is pretty sweet. What do you guys think, is it enough motor to drive a 1605 ballscrew actuator? https://www.phidgets.com/?prodid=1093
  2. Radioproffi
    Lviv
    1,659Coins
    generally good motors, but in some cases quite slow and noisy
  3. Deleted member 51784
    I have 2 on the way to test with my P3. I plan on doing a 3DOF with heave (flight simming) or a 6DOF based off of your P6 design once I verify they work as intended. The 5:1 gearbox and 1605 I'm running with the original P3 motor is too slow even for flight. I'm hoping that the faster, 4-brush motor and 4.25:1 gearbox will pick up the speed enough. I'll let you know about the noise level.
  4. Joe Cortexian
    1,429Coins
    Anything that lifts your entire weight will require >500 watts to move you an acceptable distance at an acceptable speed. So it seems way off.
    The wattage is kind of a ballpark estimate of the motors capability to do work although some motors are more efficient than others. The 12.5 kg/cm is a more accurate measure of power. This is about 1.2 newton meters. You won’t be able to move a balanced rocking rig with that motor/gearbox. If you try and run a ball screw at that speed it will be tedious at best.
    For comparison a 750w AC servo motor can run 3000 rpm at ~2.4 Nm. $150 including cables no PSU required. 220v AC is preferred.
  5. Deleted member 51784
    I was thinking that same thing, but these folks were all saying how well their rigs run with these motors. I should have checked here before ordering them. Hope I didn't just piss away $180.
  6. Deleted member 51784
    It moves pretty well. I put my 210 lb self on the corner directly over the motor and it didn't even hiccup. As @Radioproffi noted, they are louder than the original gearboxes but on par with my first version using the original motor and a planetary gearbox. I'm going to finish the second motor tomorrow, then start tuning SMC3. I've read through the setup manual and it finally clicked. It's all about inertia and mass. Here it is in motion. https://www.facebook.com/share/v/1Kup4Mav9q/ https://www.facebook.com/share/v/192USYsagG/
