Question Motor motion question
Discussion in 'New users start here - FAQ' started by riki99, May 3, 2025.
  1. riki99
    riki99 New Member
    korea
    21Coins
    In sine wave measurements, when the axis of the motor goes up, it goes up normally, but when it goes down, it goes down quickly. What should I adjust?
    151,997Coins
    +11,061 / 56 / -2
    What hardware and code are you you using and can you please post pictures of all of your settings, as you have not provided nearly enough context to answer your question.
  3. riki99
    riki99 New Member
    korea
    21Coins
  4. riki99
    riki99 New Member
    korea
    21Coins
  5. riki99
    riki99 New Member
    korea
    21Coins
  6. riki99
    riki99 New Member
    korea
    21Coins
    My system is unstable. I want to know the cause.
    151,997Coins
    +11,061 / 56 / -2
    There are a bunch of possible contributing factors.
    First, make sure the computer is set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    The SMC3 settings look like they need refinement, set Fpwm to 25kHz, at a guess increase Kp to 400 and for now set Kd to 0, then run the Sine test and post pictures of the results:
    There is also an error message when using SimTools, so hit Details and please post the full error message here, plus pictures of all SimTools settings.
    As an aside, the yellow U channel used as a a connecting link does not look robust enough and really should have spherical joints either end:
  8. riki99
    riki99 New Member
    korea
    21Coins
    Thanks to norbeast, it worked out well. And I want to add a description related to interface-output in sim tools3. If you write Axis1a, it doesn't work. If you write A<Axis1a>, it works. Thank you.
    https://youtube.com/shorts/NfArE_7Kf40?si=ps7GoUqyqSy8wzDN
    151,997Coins
    +11,061 / 56 / -2
    Glad to hear that, great job :thumbs
    It is hard to tell from the video angle but a further suggestion would be to refine the sway axis, it should lean away from a corniner. There are some handy motion profile refinement tips and tricks in the FAQs: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
