SimTools v3 Public Beta
  1. yobuddy
    51,524Coins
    The only difference I can see, is your sending the axis locations for 6 outputs in the ole settings above. But your sending the outputs for 7 on the new PC (as seen below).
  2. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    Does anyone have luck in using SimTools 3.x with ACE??
  3. yobuddy
    51,524Coins
    Are you talking about ace combat? I don't believe the game provides telemetry is the problem.
  4. saiRyu
    saiRyu Member Gold Contributor
    japan
    271Coins
    2DOF, SCN6
    I fixed the interface axis and added axis B, but the actuator still doesn't move.
  5. early_m
    early_m Active Member
    Chelmsford
    839Coins
    I think you're refering to AC Evo? Yes there is a working plugin
  6. Fahim
    Fahim Member
    553Coins
    Is there a way for you to run simulator via simtools in AI mode if you a testing a rig for say several hours?
    I don't fancy being sat on there all that time :)
    Automobilsta 2
    153,740Coins
  8. early_m
    Chelmsford
    839Coins
    I use AC for this. Just press crtl+c and the AI will drive the car (expect you may need to be using CSP)
  9. Joe Cortexian
    1,537Coins
    The surge channel in F1 24 and likely also F1 22 is just wrong. I would expect that under braking I would lean forward as far as possible and on acceleration lean back.
    I ran with only surge set and it made no sense. If anything it was a copy of the heave channel. The other channels all seem to be reasonable. On the off chance that it’s not Codemasters problem could you verify that surge channel is being extracted from the packet as you expect?
  10. yobuddy
    51,524Coins
    Both of these plugins have been tested with the plugin builder virtual plugin for correctness. So I have to believe that it comes down to your axis settings for surge. Know that it's your axis settings that takes the surge input and converts it to leaning forward for breaking, and leaning back for acceleration.
    If you have trouble figuring the settings out for surge, please post a pic of your sim with the axis labeled, and we can help you more from there buddy.
    Take care!
  11. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Hi Yobuddy,
    Really interested to run a RC car with motion in V3. I do run the RCRider in V2, it works sometime ago but not anymore connected to V2 now.
    Can we get RCRider plugin in V3?
    EDIT:
    It works again now, needs to rename the RC_Rider into RCRider
  12. UweF
    UweF Member
    Softwareentwickler, Bastler
    Kolbermoor, Germany
    84Coins
    2DOF, SCN5
    Hi yobuddy,
    I installed the v3 version some time ago with a Pro license that I have from v2. v2 is also installed, both versions work with my Simxperience hardware. In v2, the selected game waited in the game manager for the game to be started when it was ready for use (green status). It didn't matter from where and how the game was started, the main thing was that the game exe was executed and then the running game was recognized and Simtools started to do its work. How does this work in v3?
    My procedure should be as follows: I start the game from the SimCommander of Simxperience so that my seatmover is controlled by the Simcommander. Now I have built a base platform which is placed under the previous seat mover rig and this base platform raises and lowers the whole rig for the “heave” action. The platform is driven by a servo motor in conjunction with a Thanos4u controller. Now I want Simtools v3, as it was in v2, to recognize that the game is running and then start controlling the Thanos controller. However, I can only start the game in the game plugin section, which then starts and controls my Heave action, but the seatmover is not active. In principle, v3 should act as a slave in the combination of Simcommander and Simtool and Simcommander as the master.
    I hope that I have described this reasonably clearly and that you can help me here. Otherwise I will continue with v2 until this is perhaps possible in v3.
    Many thanks for your help.
  13. yobuddy
    51,524Coins
    @UweF,
    Look on the Options page in v3 for a "Auto Detect Launched Games" option.
    Enable the option and you should be good to go.
    Take care!
  14. RJ Stausebach
    RJ Stausebach Member Gold Contributor
    Ireland
    315Coins
    @yobuddy Is it possible to share the base code for the V3 DCS and MSFS2024 plugins? DCS currently has no Dash outputs, while FS2024 only has a limited number compared to V2.x
    I would think editing these would be a whole lot easier than starting from scratch?
  15. yobuddy
    51,524Coins
    @deeph46,
    I have been playing with an idea for v3 where 2 esp's directly connect to each other (over esp now) to not only receive rc-rider data, but also drive the rc car from the simulator itself. Esp now has been clocked to have a 1ms connection link that should make the ride a ton better.
    I'm not using this accelerometer pcb in this pic, but it gives a good idea of how the rc car side of things may look. This version connects to the original receiver for power, but a version that fully replaces the receiver is possible also with an added low battery alarm.
    And then the PC side of things
    I see no reason to think this would not make an super fast connection, but I have yet to give it a test to know for sure.
    May I ask what your setup looks like?
    Chat soon!
  16. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    Wow...that's interesting!!
    What setup do you refer to? Setup in RC car maybe? Like ESC and servo? Or Simtools V3 setup?
    deeph46
    EDIT : Maybe this might be minimized the wiring a bit, https://www.seeedstudio.com/Seeed-XIAO-BLE-Sense-nRF52840-p-5253.html. Ohhh...this one only has bluetooth though
  17. yobuddy
    51,524Coins
    I was referring to the hardware used to send the telemetry data. I just found that sending the telemetry data over rc hardware was not as fast as I'd like it to be, so I'm always looking for a faster way to send and receive data. On paper anyway, the esp now protocol sounds perfect, as it's commonly used for remote control vehicles.
    My understanding is that the newer BNO085 does all of the math onboard, providing ready to use euler angles. It also has other features, like stabilization and calibration save that may be handy. So that's what I was going to start with anyway. If I can get something to work, alterations to the sketch can be made for other accelerometers.
  18. deeph46
    deeph46 Member
    641Coins
    2DOF, 3DOF
    I'm using this to send telemetry data, https://www.cdebyte.com/products/E32-433T30D/2. There is also 900MHz. I also don't feel the delay, if any.
    Sounds good:thumbs
  19. Pietbrok85
    Pietbrok85 New Member
    Venlo
    47Coins
    Hello all, can anybody explain me what i have to fill in in the fields "Center of Rotation" please? Thanks a lot.
  20. yobuddy
    51,524Coins
    It's hard to say without a picture of your simulator, but this setting tells the sim where the rotation point is.
    If your sim looks like the one in the picture, then you probably do not need to make any changes.
    Know that you can test your settings in the axis assignments section or v3, while running virtual plugin to see exactly what your Sim Config settings are doing.
    Feel free to PM me if you need more help buddy.
    Take care!
