SimTools Pro Tutorial
Discussion in 'DIY Motion Simulator Projects' started by Brownboy50s, May 29, 2025.
  1. Brownboy50s
    Brownboy50s New Member
    55Coins
    Hi guys,
    I maybe totally ignorant or just missing something. I finished testing all 6 motors with SimTools, Set the percentages for Pitch, Yaw, Roll.
    How do I launch a game?
    I downloaded the free LoveForSpeed and also have the free version of Asetto Corsa. However, is there a setting I am missing to actually drive the motors during the game?
    Thank you,
    153,728Coins
  3. Brownboy50s
    55Coins
    Thank you for the reply. I am at work now, and as soon as I get back to my PC, I will send it
  4. Brownboy50s
    55Coins
    Hi, using the Output Testing on SimTools, I can see that all my motors are working with the DOF function. However, I am not sure how I can get LFS to work at least. My ultimate goal is to use this for Star Wars Squadrons or Elite Dangerous.
    153,728Coins
    If Output Testing works then it is likely a configuration issue.
    As previously mentioned LFS has to be run before it is patched for motion: https://www.xsimulator.net/communit...run-in-first-person-mode-before-patching.365/
    If that was not done then please unpatch LFS, run LFS as prescribed, and then repatch and report the results.
    Elite Dangerous is a bit more complicated to set up, but in the first instance it is important to confirm LFS works, as the default telemetry/profile configuration.
