  1. Joe Cortexian
    1,537Coins
    Unless you modify SMC3 there is no impact on performance for the third motor. Still reads the analog input, still runs at 4k still does computation for the third motor. If you comment it out it will just spend more time in idle loop because the PID calculation relies on it being 4k.
  2. Joe Cortexian
    1,537Coins
    Not sure what you mean. There are signals provided for all three motors you just wire it according to the documentation at the start of this thread.
  3. shankar sarkar
    shankar sarkar New Member
    INDIA
    69Coins
    3DOF, DC motor, Arduino, Motion platform, 4DOF
    what i mean is - the diagram which i got from the diagram from the documentation of smc3 shows only two motors and 2 IBT-2 i was wondering about the third motor.. PWM will be the next one i.e. Pin 11 but the other two ?
  4. shankar sarkar
    INDIA
    69Coins
    this is what i have
  5. Joe Cortexian
    1,537Coins
    Literally the first page of this post.
  6. Pietbrok85
    Pietbrok85 New Member
    Venlo
    47Coins
    The other pins are 6 and 7 on the arduino board when i am not mistaken.
  7. shankar sarkar
    INDIA
    69Coins
    I'M SO SORRY...no really i mean it... i straight went to the diagram never gave a look at the one you have shown...Thanks buddy.
    Regards
    shankar
  8. afrobbizz
    afrobbizz Member
    120Coins
    3DOF, 6DOF
    Hello the arduino uno r4 is working with smc3? Are there benefits to use that model?
  9. Joe Cortexian
    1,537Coins
    Not without modification. For example full power on Uno is 255 to PWM on R4 4096. A bigger change is that for Uno an int type is 16 bits R4 is 32 bits.
    Unless you want other changes there is little motivation to upgrade. These are fixable problems but simply making the cycle time faster is not going to make much difference. They have higher input resolution but you don’t need better accuracy so it’s not a benefit.
  10. Jer
    Jer New Member
    58Coins
    Hi, do you have that SMC2 yet? I'm trying to see if building a rig will be possible, and I only want 2DOF. Thanks!
  11. Joe Cortexian
    1,537Coins
    You can run SMC3 SMCUtils for a maximum of three axis. Two or even one work without limitations.
  12. Jer
    Jer New Member
    58Coins
    Oh okay, thank you! Also, does anyone have any ideas for cheap motors that I can use for a 2DOF sim with enough power preferably below $30? I don't want to spend too much on this, since it is my first time. Thank you!
  13. noorbeast
    153,758Coins
    Wiper motors are likely the cheapest easily available option, but are not very powerful and also require ground isolation: https://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    Secondhand wheelchair motors are likely a better budget option, but you will need to hunt around for them, plus shipping would be an issue if you can't get them locally. My son picked up a giveaway powered wheelchair base for nothing!
  14. Jer
    Jer New Member
    58Coins
    I found some wheelchair motors on eBay with a promising chance of working, but I have a few questions. I want to buy IBT_2 () but I dont know if it will handle a 24 volt motor without overheating. Any ideas? Also, I was wondering what common screw terminal to get, since Im knew to this electrical stuff, and I dont want any heat issues. Thank you!
    153,758Coins
  16. Joe Cortexian
    1,537Coins
    I have run ibt2 drivers for a couple of years at 24v. The issue is to get 2 good ones you need to buy 8 of them (I lost count). I also had a particular motor that the ibt2 would fail almost immediately on.
    I bought the 100amp driver which dead shorted after about 10 minutes of use taking my Uno out with it, so it’s kind of a crap shoot. I was surprised to actually get my money back from Ali Express.
  17. Jer
    Jer New Member
    58Coins
    Ok, I got some cheap IBT_2’s, and I think I will just use a 24v fan to cool everything down.
  18. Talesgc
    Talesgc New Member
    38Coins
    Motion platform
    Not working here too: upload_2025-7-31_21-57-27.png
    153,758Coins
    SMC3 is written for the Arduino Uno R3.
  20. Mistake
    Mistake New Member
    - 16Coins
    2DOF, 3DOF, Arduino, 4DOF
    Good afternoon everyone, I have a question, if I build 2 2dof circuits separately from each other, will they work in SimTools and in the game as 4dof? I want to try to build a 4dof in this way.
