CV Axle vs steering u-joint under the seat?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Opast, Jun 23, 2025.
  1. Opast
    Opast Member
    Chicago, USA
    181Coins
    3DOF, Arduino
    I'm trying to decide what to use as a U-joint under the seat for my DIY 3DOF motion simulator. What do you suggest? I'm looking for something that can move 45 degrees, but I'm not sure yet if I'll need more or less. From my research so far, driveshaft U-joints don't allow much movement. I can get a steering double U-joint 1 inch or a front drive CV axle. What do you recommend? I'll be welding to 1-inch square tubing. They all cost new between $20 - $30. I think, it'll be easier to flux core weld CV axle.
  2. Misanthrop
    Misanthrop Active Member
    826Coins
    You will not need 45° at all, in my opinion 10° is sufficient.
    153,758Coins
    An old cat down tailshaft uni joint is a very robust option, some CV joints allow lateral movement and you don't want that.
    I agree with @Misanthrop, you will not need 45° at all. Speed and precision of motion are way more important than large angles of movement.
  4. Opast
    Opast Member
    Chicago, USA
    181Coins
    3DOF, Arduino
    hmmm, how about something like that?
    153,758Coins
    Yes an old tailshaft like that works well and is very robust.
  6. Opast
    Opast Member
    Chicago, USA
    181Coins
    3DOF, Arduino
    Thanks, I'll check if it's available and I'll put an offer.
  7. Joe Cortexian
    1,537Coins
    I use a Landrover PTO ujoint because it was cheap and both sides were flat plates with bolt holes.
  8. Opast
    Opast Member
    Chicago, USA
    181Coins
    3DOF, Arduino
    How about a ball joint? They are cheap $10 - $20 and new. Easy to find. What's your experience?
      215.7 KB
      95
      64.5 KB
      101
    153,758Coins
    A poor choice in my view, as you have to then control for lateral rotation with the likes of panhard rods, unlike a U-Joint which prevents that in a way more compact and robust form, if suitably sized.
  10. Opast
    Opast Member
    Chicago, USA
    181Coins
    3DOF, Arduino
    Noorbeast, you really don't like my creativity :grin but I'm very appreciated for your criticism.
    153,758Coins
    Sometimes the tried and trusted can save you a great deal of cost, frustration, and complexity, which is why our wonderful community is such a great resource, including providing the opportunity to bounce around creative ideas and possibly get a range of perspectives ;)
  12. james wheeler
    - 143Coins
    I've had both and I would recommend CV shaft
