Motors cutting out
Discussion in 'Forum and Website' started by Matthew Sibley, Dec 22, 2024.
  1. Nash_NZ
    Nash_NZ New Member
    52Coins
    I had a similar issue, thought it was the ibt2's however after much investigation I found no issues hardware or setup wise.
    I then thought I should try a different firmware for SMC so downgraded from version 1 to 0.7 and instantly all my issues went away.
    Will none the wiser!
  2. Jodino
    Jodino New Member
    The Netherlands
    99Coins
    Hello, can you just swap the controller or does the arduino code have to change?
  3. Manuel Gonzalez
    Manuel Gonzalez New Member
    New York
    133Coins
    I just swapped the controllers
