A2M-80SV02430 servo and S2-SVD15 driver
Discussion in 'Motor actuators and drivers' started by sirbrialliance, Jul 18, 2025.
  1. sirbrialliance
    sirbrialliance New Member
    Software Engineer
    Utah
    104Coins
    Motion platform, 6DOF
    Recently picked up this servo and driver off Amazon because it was suspiciously cheap at $106 for the set.
    Sounds too good to be true but oddly enough it arrived and works.
    Here's some notes:
    • Running at 110V unloaded it's able to get up to about 3.5-3.6kRPM. Edit: see this post.
    • Running at 110V I was able to confirm, with my limited instruments, that it could produce ~6Nm peak torque. It may, with better testing and its full voltage, be able to reach its advertised peak torque of 7.2Nm. Edit: see this post.
    • There is no serial port, even if the manual/product page says there is. Not sure if the firmware would support it if you populate the empty headers.
    • It appears to use a single-turn absolute position encoder. Likely it communicates with the driver via some sort of serial method instead of the usual quadrature.
    • The encoder/position data is not available as an output on the parallel port.
    • The parellel port IO is rated for 12-24v. However, using 5v for the enable signal appears to work fine. Wired for single-ended quadrature inputs, I found I needed about 11.6v for it to work reliably. If I configured it with a fake differential signal (VCC and ground are different, right?) it seems to work fine at 5v.
    • Opening it up, it appears to have an internal brake resistor.
    • Not sure if there's any real difference between the A2M-80SV02430 servo and a regular 80ST-M02430 servo beyond the encoder.
    • It was cheaper with the holding brake, so my servo has a "Z" at the end of the model number. Pump ~24v into the holding brake connection to release the holding brake. (Background: The holding brake helps keep the servo from turning when it's unpowered/e-stopped. The servo is actually strong enough to overcome it. The holding brake is different from the brake resistor which is used to throw away power when the servo is electrically decelerating.)
    • To get wires into the black terminal thing, jam a screwdriver into the *side* and insert the wire into the round hole. I think you're supposed to be able to put a screwdriver in the top rectangular slots, but I wasn't able to get it to release that way.
    • All the parameter numbers I've looked at in the manual match up with AASD-15A parameters so far.
    @Thanos @RaaR: Hopefully that helps provide some more data to this conversation.
    @Thanos: Do you see any reason it wouldn't work with your controller? Is it an issue if the servo driver doesn't send live position feedback? Namely, does sensorless homing (hard stop torque limit) still work?
  2. Joe Cortexian
    1,537Coins
    I am confused. First you say
    • Later you say you use the quadrature encoder on the parallel port. This is a key point for me since I haven’t seen one this cheap with encoder outputs. Can you clarify?
  3. Joe Cortexian
    1,537Coins
    Also do you have e an actual manual?
  4. sirbrialliance
    Software Engineer
    Utah
    104Coins
    The current position of the drive isn't shared as a parallel port output, however, you can tell the drive where you want it to go via parallel port input (quadrature, S+D, or direction pulse). They're two different sets of pins.
    Check out the attachments RaaR shared on this post.
  5. Micknight
    Micknight New Member
    - 34Coins
    I was contemplating these same servo kits on Amazon. Looking at the pinout of Thanos' controller, there doesn't appear to be any connections to the Encoder Signal Output of the servo driver, so the lack of those outputs shouldn't be an issue for compatibility. One minor concern is... do these drivers have the high frequency "whine"? I look forward to any more info regarding your experience with these. Thank you.
  6. sirbrialliance
    Software Engineer
    Utah
    104Coins
    Yes, and an ugly EMI output, too.
  7. mycncshop
    mycncshop New Member
    48Coins
    DC motor, AC motor, SCN5, SCN6, SimforceGT, Motion platform
    Yes, as you can see, this is a low-cost servo system. It uses a magnetic encoder. The 80ST-02430 model you mentioned employs an optical encoder. While they share some compatibility in specifications and offer a degree of functional replaceability, optical encoders generally deliver superior performance overall. I hope this information is helpful.
  8. Aerosmith
    Aerosmith Active Member
    self employed
    2,881Coins
    3DOF, AC motor
    In general, I agree. But you have to be careful, there are many different types of encoders, not only optical and magnetic. The older optical encoders are incremental with different tracks for position (high resolution) and commutation (hall sensor replacement) information. Some older models have a relatively low resolution of 1000CPR. For simulators accuracy doesn't matter much but you can hear stepping noises at lower speeds. Another drawback is that they need cables and connectors with high wire/pin count (usually 14 or 15).
    Newer optical encoders have 17 or more bits resolution and only need 4 wires because they transmit the (absolute) position information over a digital interface.
    Then there are cheap magnetic encoders. They work like the hall-sensors in joysticks. You can recognize them by the magnet glued onto the end of the motor shaft and a bare PCB mouted over it. As they work like a compass they are sensitive to external magnetic fields. So if you hold a strong magnet close to the motor (or a cable with high current) the position of the servo can drift.
    The high quality magnetic encoders use a magnet wheel with multiple pole pairs. Their sensors work differentially and are (almost) immune to external fields. Permanent magnets don't cause position drift but high frequency EMI from unshielded cables can cause a bit of noise.
    I have tested cheap to medium priced drives ($100 to $300 per axis) from many different manufacturers with all of the encoder types mentioned above. The cheap ones have some disadvantages but the all run quite well and are well suited for simulation. Position drift as high as several degrees would be a show stopper for CNC applications but is not noticable for simulators.
    So my advice would be: Don't worry much about the encoder. Rather watch out for this:
    * Is there a manual available in English that explains parameter setup, wiring and tuning
    * Is the pinout of the command input compatible to your controller
    * If you're in the USA: does the servo run with 110V? Some don't like it
    * Does it make the high pitch whisteling sound (~10kHz PWM) or is it quiet?
  9. sirbrialliance
    Software Engineer
    Utah
    104Coins
    Yeah, these servos use a magnetic encoder, image attached.
    I bought 5 more and have played with them more.
    • The Thanos AMC controller appears to be able to drive things just fine with a regular DB25 cable.
    • A number of servos seem to rub lightly on the brake, even when the brake is released.
    • AFAICT, even though the magnetic encoder gives 10000p/r, the drive accepts steps with a base of 2500p/r like the AASD-15A. Again, I've yet to see a drive parameter on this that's different from an AASD-15A. This post has the manual attached.
    • Runs fine at 110v if you adjust/disable the low voltage alarm.
    • All but one of the servos I tested were able to get to 5kRPM unload at 220v.
    • Some of my earlier testing at 110v may be wrong. 3.5kRPM at 110v is probably better than the average servo.
    • I'm generally seeing around 5Nm peak torque. (Running at 220v, 0RPM, 300% rated output.) I haven't been able to reproduce the 6Nm torque I thought I got initially. I probably misread my instrument. My testing method, vice grips clamped to the shaft and an iffy force sensor, probably has more than ±10% error. Still, I don't think you'll be seeing the advertised peak torque of 7.2Nm. Running at 110v appears to give similar or somewhat reduced torque.
    • It whines and has awful EMI output.
  10. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    EMI issues can usually solved by
    • Use shielded motor cables instead of the low-cost unshielded cables provided together with the motor+driver kit. Connect the shield to PE at the driver and to the motor casing at the motor side.
    • Connect an EMI filter at the AC input. One big filter rated 16 or 20A for all drives in parallel is usually sufficient.
    • Put a ferrite ring around the U, V, and W wires at the motor output. (PE passes outside the ring)
  11. gabetjh
    gabetjh New Member
    22Coins
    im actually using this exact motor for my motion rig. I have added ferrite cores on every single cable but somehow last night my PC unexpectedly shut down due to power kernel failure, and my steering wheel occasionally disconnected randomly as well. ill send a couple of photos over
  12. Aerosmith
    self employed
    2,881Coins
    3DOF, AC motor
    Ferrite cores alone are not enough. The most important thing is the EMI filter on the AC supply side. It's also important to keep the USB ground and power ground isolated. Of course, they are connected via the PC case, but that should be the only connection.
  13. zmaniac17
    zmaniac17 New Member
    22Coins
    FYI - There's a small plastic tool in a bag that allows you to hook and press the terminal in. At least mine came with one. I ordered from Amazon as well. RATTMMotors
  14. gabetjh
    gabetjh New Member
    22Coins
    I actually build an EMI filter at AC supply side similar to the one sold by thanos at my motion but it did not work. However i resolved the problem by getting a power conditioner. So far motion has been stable and no sudden shut downs.
  15. tonni
    tonni New Member
    22Coins
    AC motor
    I actually picked up the same set not long ago and had pretty much the same experience. For the price it’s hard to believe, but mine also worked without any issues so far. The RPM and torque figures seem to line up with what you’re seeing, though I haven’t pushed it to its full limits either. The brake setup threw me off at first, but once I figured out the 24v release it made sense. Honestly, for a budget servo it feels like a solid deal, especially if you’re just looking for something to test or play around with before moving on to higher-end gear.
  16. zmaniac17
    22Coins
    Tell me about the brake. Did you need to buy a separate power supply to release it?
  17. bigjeem
    bigjeem New Member
    Mechanical Engineer
    NY, United States
    - 15Coins
    Also planning to get some of these in. With the US tariffs the 80ST's are untouchable from the usual sources. Found these from a US supplier on eBay. Even with the additional hassle to manage the electronic noise it seems like a good way to go.
  18. bigjeem
    bigjeem New Member
    Mechanical Engineer
    NY, United States
    - 15Coins
    Got the servo in and can get it to spin via an Arduino mega but having some trouble with the data stream from FlyPT. Thanos controllers are on backorder so I figured I'd go the DIY route for now. Anyone else going the Arduino route?
  19. zmaniac17
    22Coins
    I can't offer any advice yet. But I plugged them into my arduino duo running code for my 80ST 3DOF and simhub spins just fine. Though I haven't built an actuator for it so I can't full test it. Now that Aliexpress isn't shipping much to the US it's hard to build anything.
  20. bigjeem
    bigjeem New Member
    Mechanical Engineer
    NY, United States
    - 15Coins
    Ok I'll give SimHub a try. I'm still at the testing stage and gathering parts. Nothing fully built up yet. Thanks!
