Question Sim Tools - Game Engine doesn't communicate with Arduino
Discussion in 'SimTools DIY Version' started by Yenavern, Aug 13, 2025.
  1. Yenavern
    Yenavern New Member
    10Coins
    Hi everyone,
    I'm trying for first time this, is a 2 DOF with an Arduino.
    I communicate SMC3utils with my Arduino and sems to work, the motor move and
    the potentiometer works. But, when i try the output test in Game Engine, it doesn't move anything.
    My comport is 5 and I use Windows 11 Pro.
    SimTools is 2.6 version.
    Can someone help me?
  2. yobuddy
    51,541Coins
    Please make sure that the SMC3utils app is closed before using SimTools, or it will not be able to connect.
  3. Yenavern
    Yenavern New Member
    10Coins
    Yes, I restarted the PC but still not working.
    I should mention that I only have one IBT2 for testing. Maybe that affects it?
    Should it only work with one driver?
    153,920Coins
    +11,156 / 57 / -2
  5. Yenavern
    Yenavern New Member
    10Coins
    Yes, I patched LFS with GameManager, and that one conect with Game Engine, I can see that red square turn in to blue.
    Maybe need to detect all the potentiometer?
    I Attach a photo of what I have
    153,920Coins
    +11,156 / 57 / -2
    Can you please post a picture of SMC3 running the Sine test.
  7. Yenavern
    Yenavern New Member
    10Coins
    Yes, here is the picture:
    Shakes a lor because i don't have the best joitn, is just tape for the test.
    153,920Coins
    +11,156 / 57 / -2
    Please configure a Default Porofile and report if Output Testing works as expected.
  9. Yenavern
    Yenavern New Member
    10Coins
    Thank you, finally works.
    I think that the problem was in potentiometer, because when it goes to 0% or 100%, all gets down.
    Some times, when potentiomer shakes goes to 0%
    I change the potentiometer and all is working.
    Thanks guys.
  10. evgenymcp
    evgenymcp New Member
    79Coins
    I've been working with electronics for a long time, and I can say with 100% certainty that classic potentiometers are not suitable for our tasks. I have to replace them regularly in my laboratory power supply because they fail even during storage due to temperature and humidity fluctuations, causing contact loss, not to mention mechanical stress. They will quickly deteriorate in the zero zone due to the constant movement of the servo. It's a waste of time. I have experimented with the AS5600, and I have had a positive experience with this sensor. I'm currently testing the OOTDTY R9UA 360-degree digital potentiometer.
