Question How to do proper motion compensation with Simtools?
Discussion in 'Forum and Website' started by VFX Pro, Aug 18, 2025.
  1. VFX Pro
    VFX Pro Member
    Los Angeles
    431Coins
    Motion platform, 6DOF
    I have a ProSimu P7MP (6 DODF) and want to get into VR. The problem is I can't find anything that would work with Simtools. I have seen videos with witmotion, or lighthouse, etc... but they all work with SRS or SimHub.
    I would hate to leave SimTools behind... Any tips to get this working properly?
  2. Joe Cortexian
    1,549Coins
    There is a bit of confusing and misleading information out there. I have the Quest 3. I attached my right controller to my rig configured it and it just works. I use OVRMC for SteamVR and most games. It puts a menu in SteamVR (left controller menu). Set it to right controller and enable. This is straightforward.
    The exception is MSFS which doesn’t work for me from SteamVR. I have also loaded OXRMC which works with Oculus native graphics. There is an init file you have to edit to select the right controller and enable. I have it enabled automatically but you can define key sequences to enable and disable.
    I know this works for Quest 2 and Quest 3 and don’t see any reason why it would not work for other headsets as well.
    153,920Coins
    +11,156 / 57 / -2
