6DOF anti collision algorithms
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Aerosmith, Dec 29, 2024.
  1. Aerosmith
    Aerosmith Active Member
    self employed
    2,875Coins
    3DOF, AC motor
    While designing my rig I ran into the problem that there are poses possible that cause collisions. There are internal collisions where the actuators hit the rig structure.
    Or external collisions where parts of the rig hit the floor or the ceiling.
    I know, my rig is very special. It has two seats so it's larger than most others from the beginning. I also made the decision (against all advices) not to use VR but instad install a big curved screen. I have to admit that it would be much easier to avoid collisions if I made it like most others do: use VR and place the actuators in a circle around the rig instead of below the platform. But with two seats (1.4m width) that would require even more space and an actuator stroke of >1m to achieve reasonable roll and pitch ranges.
    And even with the "easy" way of placing the seat between the actuators it is still possible to have collisions.
    With pitch down and yaw at the same time the pedal board could hit one of the actuators. So I'm sure I'm not the only one with this problem.
    I have heared that there are plans to implement an anti collision feature in FlyPT Mover. I'm not sure how it works. But calculating the whole mechanical model of the rig and do a object-by-object collision detection would surely be too complicated. And it's not enough to detect a collision. That would be already too late. Velocity and acceleration have to be continous both for each actuator (rotating motor intertia) and the pilot (too much jerk -> risk of injury). So potential collisions have to be foreseen to be able to slow down before it actually happens.
    So I'm looking for a mathematical model to avoid collisions by not only limiting variables like heave or pitch seperately but by monitoring them all simultanously and apply some sort of "dynamical soft limit".
  2. Aerosmith
    self employed
    2,875Coins
    3DOF, AC motor
    The collision in the first picture in post #1 can be avoided by limiting pitch to +/-30° which should be enough for most cases. If you want to do loopings you need a cardanic suspension with +/-360° range instead of a stewart platform, anyway.
    Most collision cases happen where multiple extreme poses occur simultanously, for example extreme pitch and extreme roll. In extreme heave positions (all actualtors fully extended or fully retracted) the stewart kinematics is self-limiting, e.g. no other movements like pitch, roll, sway or surge are possible, anyway. But with heave centered poses can add up to problematic positions.
    So what we need is to "cut the corners" of the space of possible movements. Let's consider the 3-dimensional space of heave, roll and pitch.
    The vertical and horizontal walls of the cube are the individual limits while the cut corners mean that the limits are stricter when two or more variables are at the extreme values simultanously.
    For a stewart platform the space of possible movements has 6 dimensions which is difficult to display on a 2D screen. But mathematically it's still possible to calculate distances, shapes and angles in 6d-space.
  3. pmvcda
    15,702Coins
    For now, flypt mover controls colissions with tne pedals, but i plan to add custom collisions.
    It also limits singularity by not allowing angles bellow a specific value and compresses motion to fit limits
  4. Aerosmith
    self employed
    2,875Coins
    3DOF, AC motor
    The possibility to calculate distances is important to foresee possible collisions. If the current position becomes closer to one of the walls of the limiting polyhedron we can slow down the movement before actually hitting the wall. A 6-dimensional "ball" would possibly be easier to calculate than a polyhedron with many surfaces.
    If the distance to the limiting sphere is greater than the braking distance for the given speed we have to do nothing at all. If it is smaller we have to check the vector component in the direction towards the sphere. If a "collision course" is detected it has to be slowed down. A perpendicular movement (parallel to the sphere) is harmless.
    The problem is that by cutting off the corners of a 3D cube we don't remove much volume. So the limitations are not that severe. Extreme positions for all degrees of freedom at the same time do not occur very often. But in 6D space the corners possibly have more volume than the enclosed sphere.
  5. Aerosmith
    self employed
    2,875Coins
    3DOF, AC motor
    That's great!:thumbs The singularity/angle limit will surely solve my internal collision problem (see first picture in post#1). Do you already have an idea how to implement custom collisions? calculating a true 3D model of the collision sensitive parts of the rig would be the most universal aproach but computationally intensive and complex and error prone for the users to setup.
    The 6D-sphere method is mathematically elegant but very counter-intuitive. Most people would hate it. And it's also not necessary. I think, adding contraints to 2 or 3 degrees of freedom is enough in most cases. For example the condition
    ABS(surge)+ABS(sway) < 1.5*range
    with "range" representing the max. individual value of sway and surge would cut the square of reachable positions into an octagon. And in my case
    heave+ABS(roll)+ABS(pitch) < limit
    would prevent the curved screen from hitting the ceiling. It's possible to calculate angles and velocity vectors in the corresponding 3D subset-space which enables collision prediction and decelleration in advance.
    Setting up the conditions for collision prevention does not require math skills. You could just select the DOFs you want to limit. Then you can find the appropriate value for the range factor (1.5 in the example) by trying out. Carefully move the rig close to the point where the collision could occur with the test sliders in the pose window and the factor can be automatically be calculated from the current position.
  6. GRAP
    GRAP Member
    Dog handler, Maitre chien
    Montpellier
    214Coins
    Hi
    if you open the legs on the floor. You have place and no collision
  7. pmvcda
    15,702Coins
    @Aerosmith ,
    Sorry, been on holidays. Now back.
    So What Mover does for now is colision with pedals and singularity.
    Singularity is to avoid the actuators being on the same plane of the top platform. We set the minimum angle allowed and the rig doesn't move.
    With the motion alghorithms you can allow movement making it work like a kind of logistic, decreasing movement near the limits.
    For the pedals you define a 3d vector (start and finish) and it's radius (also the radius of the actuators).
    If the axis are to close, there's risk of colision and the rig acts like in singularity depending on motion alghorithm.
    The axis is visible in the 3d view and enabled if you set the radius (radius=0 is disabled)
    Here in colision
    The axis/volume as a start and finish defined by 3D points and you can set any axis...
    What you can also do for now is use the pose filters to limit movement with crop, allowing different values for each of the dof's and minimum/maximum.
    What I plan to add is triangle and plane colisions. Planes/triangles will be assigned to fixed or moving parts.
    You set 3 points in space, assign it to base/top (fixed/moving) a say if that is a triangle or a plane.
    Any intersection is a colision. This is an idea for now and should have some problems, but would allow many solutions.
    Another idea is basic volumes like the cylinder, sphere, pyramid, cone, cube colisions where we define them like above. In reality they could be multiple triangles.
    This might take some time to be done. There's other priorities for now.
  8. Leslie
    Leslie New Member
    Retired electronics engineer
    South Yorkshire, United Kingdom
    250Coins
    Hi, this might actually not be a problem. Are you sure you're going to use anything like the maximum potential pitch/roll/yaw angles ? You mention limiting pitch to +/- 30 degrees. In my fully enclosed sim I never approach anything like that.
    During development (when my platform was definitely not fully enclosed) I ran the motion software with the washout disabled (because I had stationary visual cues of the workshop it seemed to feel more correct with the platform trying to mimic (as far as possible) the attitude of the aircraft as regards pitch and roll etc). And I did achieve some pretty extreme angles. It didn't feel right though as far as realistic motion is concerned.
    However, now that my platform is fully enclosed (so I have no external stationary visual cues) and with the washout enabled in the motion software I found the actual pitch and roll angles being used were much less, and the motion feeling was very much better !! Definitely as case of less is more !!
    During the early design phase of my project I was determined to go for the largest actuator stroke I could reasonably afford - to give me something like +/- 30 degrees of pitch and roll, but with hindsight I now believe this isn't necessary, and that realistic motion (in a fully enclosed environment with the correct software) can be achieved with as little as +/- 10 degrees.
    I realise your available space limits the layout/design of your platform but I hope the collision issue may not be as big a problem as it might seem.
  9. Aerosmith
    self employed
    2,875Coins
    3DOF, AC motor
    For the helicopter simulator this is definitely true. I'll never need more than 30° roll and pitch. Even if I fly a simulated turn with a bank angle of 45 or even 60° the nacelle is hanging straight on the rotor mast so the force always goes straight up no matter how the helicopter is oriented in space. There are only small movements required to simulate the acceleration.
    However, Sven also wants to use his rig for car racing. If you do a tight turn with a car the centrifugal forces can easily become as high as 1g. So you would theoretically need 45° roll to make horizontal and vertical acceleration equal. We need to limit this. Clipping the values seperately is easy. But even if the rig can do a 30° roll a simultanous roll and yaw will likely cause a collision. This scenario can happen quite often when you loose traction in a turn. You're already at the max. roll angle and the sudden yaw will slam the pedal area into one of the actuators. Crashing into the guard rails while applying max. braking is another risky screnario (max. pitch down + sudden sway) which will happen sooner or later.
    And yes, "static" cues where the position angles are not high-pass filtered (washout) don't feel right. For example if you do a left turn with a plane you roll to the left but this creates an acceleration vector pulling you to the left which is not what you'd expect. The acceleration vector is important, not the actual/absolute position. Therefore it's important to hide any visual cues to the outside world. You either need VR goggles or a fully enclosed cabin.
  10. sirbrialliance
    sirbrialliance New Member
    Software Engineer
    Utah
    104Coins
    Motion platform, 6DOF
    Since just checking a collision isn't enough to slow motion in advance, some technical thoughts:
    Signed distance fields: imagine you have a function that simply tells you the distance to the nearest obstacle. Each motion step, you can check to see if anything is nearing a defined limit. If you are, and based on how close you are getting, you can reduce motion. Take the derivative of this function and you can quickly determine if a given motion vector moves you closer or farther from the obstacle.
    In practice, it'd be a pain to code up because you can't just drop in an existing physics library's collision detection. (But, also, at heart, the underlying math for at least some collision detection algorithms could be easily adapted to return distance instead of hit/miss.)
    Or one could fake it. Use a regular physics library's collision detection, but make "layers" of triggers larger than the colliders they represent. (e.g. the ceiling, but 100mm lower, the ceiling but 300mm lower, etc.) Then, as you progressively enter these triggers you can slow the motion in steps. (The penetration normal on the trigger collisions might or might not be reliably useful for knowing if you're getting closer or farther, however...)
    It's not a simple problem, but some ideas.
  11. Aerosmith
    self employed
    2,875Coins
    3DOF, AC motor
    Detecting potential collisions of the actual mechanical parts accurately would require processing of the actual 3D CAD models of the actuators, joints and cockpit nacelle. That could theoretically be done but is too complicated to me. It would additionally require to calculate forward and reverse kinematics of the Stewart platform as I had to modify the original positions output my FlyPT Mover. Reverse kinematics (calculating the actuator stroke from the rig position) is easy but forward (rig position in space from the actuator position) is hard.
    So I think I'll stick to the "multi-dimensional cube with cut corners" model described in post #2, maybe together with a combination of the anti-collision feature of FlyPT Mover.
